Change Default DVR Library To Record To
Server Version#: 1.19.1.2645
Player Version#: HDHomeRun 20200225
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I moved my PMS from Windows 7 to Ubuntu 18.04, including the metadata. All of my scheduled recordings imported fine, but when they were set to record they failed. I determined that when I scheduled a new recording it worked fine. Upon closer inspection, it appears that it was because it was recording to the TV Shows library. The pre-existing schedule recordings were set to record to DEFAULT library and there is no option to change in the dropdown.
I now have to go through scheduled recordings, cancel and re-schedule each one with an option of TV Shows for the library to record to unless there is a way to update this for all. I’ve never messed around with the database, but I’m assuming that is likely going to be the way to do this unless there is soe option I’m not aware of in the web app UI?
