Channel guide errors & mapping issues
Server Version#: 1.18.8.2468
Player Version#: 1.6.3.1009-57cf57c8
Starting several days ago my Summit digital swfl channel guide has 8 unplayable SD channels (11, 18, 36, 37, 40, 46, 79 & 90) that do not appear in the DVR manage channel list and is missing the 8 HD versions of those channels (311, 431(18 hd equal), 336, 337, 340, 346, 379 & 390) that do appear in the manage channel list. When I modified my HDHR Prime3 to unblock channel 11 & 36 and enabled them in the DVR they will play providing I don’t also try to enable 311 & 336. If I try to enable 11 & 311 I get an error message that both 11 & 311 are mapped to 311. Ditto for 36 & 336 - DVR says both are mapped to 336.
How do I get the 8 SD channels out of the guide and get the 8 HD channels back?
see pics
I believe this is a known issue with v1.18.8 that’s being looked at; I would recommend downgrading to 1.18.7 and make sure your update channel is set to public instead of beta):
see also @ Live TV, Comcast with HDHR Prime, channels incorrect, unable to tune
Thank you. The 1.18.8 version is indeed the issue. I had deleted my plex data folder trying to fix the guide issue but found a 1.18.7 version in my downloads folder. I uninstalled the .8 version and installed the .7 version and the guide issues were gone until Plex automatically updated to the .8 version. This morning I uninstalled Plex and installed the .7 version again & set Plex to ask before updating. How will we know when Plex has fixed the guide issue for new versions?
On the settings page for the SERVER, click on What's New which contains the release notes; look for a related fix.
Alternatively, follow this thread and review the release notes there.
