Channel not found after frequency change
Two of my local channels just changed frequencies as a part of the FCC reshuffling, and i’m not able to select them in the guide. I attempted to rescan but the new channels didn’t appear, and their old listings disappeared.
WISH 8.1 etc.
WNDY 23.1 etc.
They have the same digital/virtual channel number (8.1/23.1) but have switched RF frequencies. When i hooked the antenna into the TV next to the server and scaned for the new channels, they appeared without issue. Thought it might be an issue with zip code for the guide, so i tried another close one, but ended up with fewer channels. I live in 46038, and tried 46220
Windows 10 server
Version 1.13.5.5291
hauppage wintv quadhd tuner
Not sure what i’m missing, any help would be appreciated.
I’d imagine you need to delete the DVR, and recreate it, and scan for channels again. Otherwise the DVR won’t know the frequency has changed. :slight_smile:
I swear I tried that! Thinking I was humoring you, I tried that again, and it worked! WOO! Thanks.
