Server Version#: 1.13.6.5339 Player Version#: 2.16.2
Do the XML files for each client profile (ie. Xbox One.xml) get overwritten after each update? The reason I ask is that the default Xbox One.xml profile seems to prefer AAC to AC3 for audio trancodes. This causes SERIOUSLY poor/low audio for basically all my files since they are DTS and thus have to be transcoded on the Xbox One. Changing the profile settings to prefer AC3 seems to fix the issue but if this gets overwritten after each update the fix becomes untenable.
If you place a custom XML file in the Profiles directory, which you create under Plex Media Server, it is never overwritten and always loaded in favor of the distribution default profile.
If the default profile has been loaded (used once), PMS must be restarted in order for the customized profile to take precedence or be updated. This is because they are loaded into memory at first use and not read again.
I see what he said but it wasn’t (and still isn’t) very clear. So I create a new Profile (ie. Xbox One New.xml). Do I delete the default Xbox One.xml? If not and both are there, how does the Xbox know to use the Xbox One New.xml over the Xbox One.xml?
Every XML I’ve referred to in this thread is in the /usr/lib/plexmediaserver/Resourcse/Profiles directory. Is there some other directory that has XML’s?
Yes, there is another. The master copy. The one PMS uses when you don’t have a custom profile.
[chuck@lizum Profiles.107]$ pwd
/usr/lib/plexmediaserver/Resources/Profiles
[chuck@lizum Profiles.108]$ ls
Android.xml Opera.xml Sonos.xml
Asus Transformer Prime TF201.xml Panasonic Viera 3D TV.xml Sony Blu-ray 2013.xml
Chromecast.xml PlayStation 3 App.xml Sony Blu-ray.xml
Chrome.xml PlayStation 3.xml Sony Bravia 2010.xml
cloudsync.xml PlayStation 4 App.xml Sony Bravia 2011.xml
Firefox.xml Plexamp.xml Sony Bravia 2012.xml
Generic.xml Plex Desktop.xml Sony Bravia 2013.xml
HTML TV App.xml Plex Home Theater-RaspberryPi.xml Sony Streaming Player.xml
Internet Explorer.xml Plex Home Theater.xml sugar.cmake
iOS-iPad-1,1.xml Popcorn Hour.xml tvOS.xml
OK, that’s where I was editing the Xbox One.xml as it’s the only spot I’ve found profiles. What is the directory I should be creating this default profile in?
Is there some way to confirm via logs what profile is being used? And do I need to name my custom profiles the same or different from the default ones?
The clients are keyed to the XML names.
The only distinction between stock versus customized is the file location (in your “Library”)
The logs will confirm only by reporting their behavior, typically when the MDE (Media Decision Engine) engages to determine how to play an item.
Ok so it doesn’t appear that my custom profile is being used because it’s still converting DTS audio to AAC instead of AC3 even though I have the order as “ac3, aac, etc.”
