Collections displayed in Friend's Home but is restricted using labels
Server Version#: 1.41.8.9834
Player Version#: 4.146.0
Server Platform: Docker on Ubuntu
Bug:
Collection that is restricted using labels on the collection and restricted labels on a library share is still displayed on the Friend’s Home despite being restricted. The collection itself is not shown in the library but in the home.
Setup:
Create a label, edit the library share and add that label to Exclude Labels. Add that label to a Collection to restrict it. Change Visible on to Friend’s Home.
Stupid idea but maybe the labels are case sensitive?
On the collection you’ve used Restricted while on the restriction page of the user “F” you’ve used restricted with no upper letter! :wink:
Just Checked nope that’s not the problem and for some reason if you add a label to a collection it automatically capitalizes the first letter
Will edit the screenshots thanks for the message :grin:
Yeah that’s a long time issue with collections. The collection itself does not have a label so it shows up. It’s not until you enter the collection that it knows there is nothing inside to show.
I wonder if adding a label manually to the collection in the database would fix this.
Just confirming this is still an issue and is easily reproducable.
To reproduce (requires seperate user test account):
1: Create a collection
2: Add label testing123
3: Set visibility to Users Home and Library Recommended
4: Set testing123 as a label restriction for the test user for the library you created the Collection in
5: Login to the test users account
4: On the Home page and Library Recommended, the Collection that shoud be restricted is fully visible
See additional reports here and here
