Server Version#:1.28.2.6151
Player Version#:1.52.1
I have named the files as such:
Star Trek - The Next Generation/Season 01/Star Trek - The Next Generation - S01E01-E02 - Encounter at Farpoint {thetvdb-71470} - [1080p BluRay 58FA97C3].mp4
Star Trek - The Next Generation/Season 01/Star Trek - The Next Generation - S01E03 - The Naked Now {thetvdb-71470} - [1080p BluRay D837587F].mp4
For some reason plex is listing E03 as E02 and every episode thereafter is off by one. It’s listing the first two episodes as being 1 hr 31 minutes. Only the combined E01-E02 is that long.
I have removed the whole season, cleaned bundles and optimized the DB and re-added the season to no avail.
I believe the files are named according to plex standards.
I would appreciate any advice. Thank you.
Looking at Info for the Season I see something odd. Plex has created two links to the same file.
In addition, should {thetvdb-71470} be {tvdb-71470} and shouldn’t it also be at the top level series folder rather than individual episodes ?
Most likely not related to this issue as it appears to be ordering as per @VBB post but its certainly not per the plex naming guidelines and may (or may not if your lucky) cause other problems.
Thank you. I set this all up to be renamed using FileBot way back at the beginning of this feature for TV shows. I think at that time it was “thetvdb”? In any case I have changed it now.
