Hey there
Using Server Version 1.13.2.5102
After deleting my DVR device (because some major errors in the program guide), trying to re configure my HomeRun Device.
Everything works perfectly until I try to enter my 4 digit ZIP code for my town in Switzerland.
With a 4 Digit ZIP code I can’t continue the Installation (continue button is grayed out).
This definitely worked with the older Versions of PLEX Server.
Must be a bug thow.
Samuel
A fix is being produced and will be released in a future version of Plex media Server
Should also change any references from Zip Code to Postal code as well.
I’m facing the same. Still not fixed as of 1.13.2.5142.
Still not working with 1.13.2.5154
Is there a release planning available for users?
:s
It’s also no longer working for me, would be great if that would be fixed soon.
Hi, same problem for switzerland. Can’t process … it’s boring …
Is there any possibility to fix it independently without having to wait for the next update / release?
On the older release (about 3 months ago) it worked fine.
The fix for Switzerland has now been released in beta version 1.13.3.5208
See Release Note Plex Media Server - #222 by drzoidberg33
- (DVR) Check for the correct postal code format for Switzerland (#8646)
Still not working for me under 1.13.3.5208.
Yes, still doesnˋt work…
sorry for this - Problem understood. Discussing with the development team
Sorry for the earlier glitch. The fix is definitely in the hotfix beta release that is available now - version 1.13.3.5223
I confirm it’s now working as of 1.13.3.5223. Thank you!
Yes, it works now!
Perfect thanks!
Yes, it works now!
Perfect thanks!
