Server Version#: 4.12.3
I’m not very technical, so I wasn’t sure what I should paste from my logs, but I do keep getting these Plex diagnostic reports and wondered if there was an issue with the installation on my 2018 Mac mini 3.2 GHz-6Core i7 with 16 GB RAM. Is this something I need to fix?
Date/Time: 2019-12-27 05:11:14 +0100
End time: 2019-12-27 05:15:19 +0100
OS Version: Mac OS X 10.15.2 (Build 19C57)
Architecture: x86_64h
Report Version: 29
Incident Identifier: 55D8D54C-D4DB-4A58-99F2-7189CDAF9D53
Data Source: Microstackshots
Shared Cache: 0x8a7a000 8E6218E5-F57C-3DD8-A866-794D28F8B755
Command: Plex Media Server
Path: /Applications/Plex Media Server.app/Contents/MacOS/Plex Media Server
Identifier: com.plexapp.plexmediaserver
Version: 1.18.4 (1.18.4.2171)
PID: 560
Event: wakeups
Action taken: none
Wakeups: 45001 wakeups over the last 245 seconds (184 wakeups per second average), exceeding limit of 150 wakeups per second over 300 seconds
Wakeups limit: 45000
Limit duration: 300s
Wakeups caused: 45001
Wakeups duration: 245s
Duration: 244.62s
Duration Sampled: 203.54s
Steps: 26
Hardware model: Macmini8,1
Active cpus: 12
Boot args: chunklist-security-epoch=0 -chunklist-no-rev2-dev
Heaviest stack for the target process:
26 thread_start + 15 (libsystem_pthread.dylib + 6203) [0x7fff6bcf883b]
26 _pthread_start + 148 (libsystem_pthread.dylib + 24165) [0x7fff6bcfce65]
26 boost::(anonymous namespace)::thread_proxy(void*) + 139 (libboost_thread.dylib + 12235) [0x110417fcb]
26 ElasticThreadPool::run() + 48 (Plex Media Server + 12015136) [0x10cf57620]
26 boost::asio::detail::scheduler::run(boost::system::error_code&) + 210 (Plex Media Server + 1630786) [0x10c570242]
26 boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) + 799 (Plex Media Server + 1631903) [0x10c57069f]
26 boost::asio::detail::completion_handler<boost::_bi::bind_t<void, boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>, boost::_bi::list3<boost::_bi::value<ElasticThreadPool*>, boost::_bi::value<boost::function0 >, boost::_bi::value<void*> > > >::do_complete(void*, boost::asio::detail::scheduler_operation*, boost::system::error_code const&, unsigned long) + 127 (Plex Media Server + 12016223) [0x10cf57a5f]
26 void boost::_bi::list3<boost::_bi::value<ElasticThreadPool*>, boost::_bi::value<boost::function0 >, boost::_bi::value<void*> >::operator()<boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>, boost::_bi::list0>(boost::_bi::type, boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>&, boost::_bi::list0&, int) + 108 (Plex Media Server + 12016620) [0x10cf57bec]
26 boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>::operator()(ElasticThreadPool*, boost::function0, void*) const + 122 (Plex Media Server + 12016842) [0x10cf57cca]
26 ElasticThreadPool::runner(boost::function0, void*) + 47 (Plex Media Server + 12012863) [0x10cf56d3f]
19 ButlerRequestHandler::execute() + 207 (Plex Media Server + 500943) [0x10c45c4cf]
19 ButlerRequestHandler::createTaskGenerator() + 436 (Plex Media Server + 503876) [0x10c45d044]
17 ButlerSubTaskGeneratorDeepMediaAnalysis::start() + 568 (Plex Media Server + 594888) [0x10c4733c8]
14 MetadataItem::FindWithMediaData(Database const&, int, int) + 711 (Plex Media Server + 5611879) [0x10c93c167]
9 void Database::GetList(soci::statement&, std::__1::vector<std::__1::shared_ptr, std::__1::allocator<std::__1::shared_ptr > >&, MetadataItem&) + 59 (Plex Media Server + 4968475) [0x10c89f01b]
4 soci::details::statement_impl::fetch() + 80 (libsoci_core.dylib + 120400) [0x10dead650]
4 soci::sqlite3_statement_backend::loadRS(int) + 339 (libsoci_sqlite3.dylib + 35299) [0x10dedc9e3]
4 sqlite3_step + 2446 (libsqlite3.dylib + 64478) [0x10f171bde]
2 sqlite3VdbeExec + 22580 (libsqlite3.dylib + 305092) [0x10f1ac7c4]
2 handleDeferredMoveto + 35 (libsqlite3.dylib + 372163) [0x10f1bcdc3]
1 sqlite3BtreeMovetoUnpacked + 1869 (libsqlite3.dylib + 352189) [0x10f1b7fbd]
1 moveToLeftmost + 146 (libsqlite3.dylib + 379842) [0x10f1bebc2]
1 getAndInitPage + 98 (libsqlite3.dylib + 374642) [0x10f1bd772]
1 getPageNormal + 508 (libsqlite3.dylib + 211244) [0x10f19592c]
1 readDbPage + 201 (libsqlite3.dylib + 212073) [0x10f195c69]
1 pread + 10 (libsystem_kernel.dylib + 9958) [0x7fff6bc3a6e6]
AND
Date/Time: 2019-12-27 05:11:27 +0100
End time: 2019-12-27 05:13:06 +0100
Report Version: 29
Incident Identifier: 7512F625-2949-4534-894D-5A0815CCA9D4
PID: 560
Event: cpu usage
Action taken: none
CPU: 90 seconds cpu time over 99 seconds (91% cpu average), exceeding limit of 50% cpu over 180 seconds
CPU limit: 90s
Limit duration: 180s
CPU used: 90s
CPU duration: 99s
Duration: 98.66s
Duration Sampled: 73.08s
Steps: 17
Active cpus: 12
17 thread_start + 15 (libsystem_pthread.dylib + 6203) [0x7fff6bcf883b]
17 _pthread_start + 148 (libsystem_pthread.dylib + 24165) [0x7fff6bcfce65]
17 boost::(anonymous namespace)::thread_proxy(void*) + 139 (libboost_thread.dylib + 12235) [0x110417fcb]
17 ElasticThreadPool::run() + 48 (Plex Media Server + 12015136) [0x10cf57620]
17 boost::asio::detail::scheduler::run(boost::system::error_code&) + 210 (Plex Media Server + 1630786) [0x10c570242]
17 boost::asio::detail::scheduler::do_run_one(boost::asio::detail::conditionally_enabled_mutex::scoped_lock&, boost::asio::detail::scheduler_thread_info&, boost::system::error_code const&) + 799 (Plex Media Server + 1631903) [0x10c57069f]
17 boost::asio::detail::completion_handler<boost::_bi::bind_t<void, boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>, boost::_bi::list3<boost::_bi::value<ElasticThreadPool*>, boost::_bi::value<boost::function0 >, boost::_bi::value<void*> > > >::do_complete(void*, boost::asio::detail::scheduler_operation*, boost::system::error_code const&, unsigned long) + 127 (Plex Media Server + 12016223) [0x10cf57a5f]
17 void boost::_bi::list3<boost::_bi::value<ElasticThreadPool*>, boost::_bi::value<boost::function0 >, boost::_bi::value<void*> >::operator()<boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>, boost::_bi::list0>(boost::_bi::type, boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>&, boost::_bi::list0&, int) + 108 (Plex Media Server + 12016620) [0x10cf57bec]
17 boost::_mfi::mf2<void, ElasticThreadPool, boost::function0, void*>::operator()(ElasticThreadPool*, boost::function0, void*) const + 122 (Plex Media Server + 12016842) [0x10cf57cca]
17 ElasticThreadPool::runner(boost::function0, void*) + 47 (Plex Media Server + 12012863) [0x10cf56d3f]
17 ButlerRequestHandler::execute() + 207 (Plex Media Server + 500943) [0x10c45c4cf]
17 ButlerRequestHandler::createTaskGenerator() + 436 (Plex Media Server + 503876) [0x10c45d044]
