Constant scanning of my files
I am a new user, and i am not sure everything is set up just right. How often is Plex supposed to scan my folders? i think i would call this excessive. I can’t even scroll through now playing, and coming up with out THAT refreshing too. its a bit annoying, and makes it cumbersome to use. Any ideas? I copied and pasted just a snipit of the constant scanning.
7:23pm Library scan complete: Extra information may still be downloading from the Internet
7:23pm Finished processing Marvel’s Agents of S.H.I.E.L.D.
7:23pm Downloading metadata for Marvel’s Agents of S.H.I.E.L.D.
7:23pm Scanning Application Support/Plex Media Server/Logs/PMS Plugin Logs
7:23pm Scanning the “My DVR” section
7:23pm Scanning Application Support/Plex Media Server/Plug-in Support/Databases
Enable debug logging on the server, restart the server and then when you notice the problem get full server logs zip
See
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
What path / paths have you defined for My DVR library?
And are they any files changing there all the time?
May be there is an error and it is repeating the action - need to see the server logs
