Plex seems to think so. It’s scanning it.
Okay, there seems to be alot going on in your logs.
Jun 11, 2019 03:11:24.951 [8048] DEBUG - Adding file for scanner: "M:\Exposed.2016.LIMITED.1080p.BluRay.x264-AN0NYM0US\ams-exposed-1080p.r00"
Jun 11, 2019 03:11:24.976 [8048] DEBUG - Adding file for scanner: "M:\Exposed.2016.LIMITED.1080p.BluRay.x264-AN0NYM0US\ams-exposed-1080p.rar"
Are you using plex as a download directory? This WILL cause issues with constant scanning because plex detects changes(every chunk from your download manager).
Jun 11, 2019 03:11:25.922 [8048] DEBUG - * Scanning directory M:\plex copy\Plex Media Server\Plug-ins\Services.bundle\Contents\Service Sets (parent: yes)
Again, why is Plex scanning a metadata folder?
You have hundreds of these across your logs.
There are many issues that need addressed here.
It’s not a good idea to make the ROOT drive your Plex ROOT folder(M:)
The reason for this is because many other programs may add stuff here.
An example of this is…
Jun 11, 2019 03:11:24.708 [8048] DEBUG - Adding file for scanner: "M:\com.plexapp.agents.hama.log"
Jun 11, 2019 03:11:24.709 [8048] DEBUG - Adding file for scanner: "M:\com.plexapp.system.log"
and
Jun 11, 2019 03:11:24.772 [8048] DEBUG - Adding file for scanner: "M:\_root_.agent.log"
Jun 11, 2019 03:11:24.772 [8048] DEBUG - Adding file for scanner: "M:\_root_.scanner.log"
Jun 11, 2019 03:11:24.772 [8048] DEBUG - Adding file for scanner: "M:\_root_A -Anime.filelist.log"
Jun 11, 2019 03:11:24.772 [8048] DEBUG - Adding file for scanner: "M:\_root_A -Anime.scanner.log"
I hate to say it but your entire library(all of them) needs a gigantic overhaul.
Start with folder structure. First with movies, then tvshows.
https://support.plex.tv/articles/categories/your-media/
This will be a colossal PITA but it must be done for a blissful plex experience.
