Hi
It appears that Plex only shows the “continue watching” from my Movie library, but not my TV/Series library.
How can I make Plex show me the series (as in the episodes) I was watching as well?
For some reason Plex is also only showing 8 items, when I know that I have more than 8 unfinished movies to finish…
Are you running the latest PMS and using the hosted Web app? There was a bug previously that limited the hub from how many items it showed. Should be fixed now.
And CW should include tv show episodes, if your TV show library is pinned to the sidebar. Could be hiding behind your current 8 limit.
… and here’s the spot for the limit setting:
At my house - it took a few days to get all 35 items.
I was young then.
Note:
If those movies you haven’t finished watching are on Pause - you’ll have to hope you have enough slots - 'cause your shows will always be at the end of that list.
This may stop that scenario (I’m not sure):
Thanks for the replies! I have checked the settings (and changed them, just in case) but even with a setting of 50 weeks, and a max of 40 items, the series do not appear in the list.
I mean, one of the movies in the list is one I had stopped watching a loooong time ago, but a series I just tried to play just now has not appeared in the list…
Yep! All there, along with other libraries
Maybe you got the bug.
All Updated?
Server and Clients?
Yep, server updated today with latest release.
Player is the web player, or iOS App.
Good thing there are a few Employees in this thread then (I saw one behind a tree a while ago)…
they won’t have far to travel…lol
AAahhh… I found it!
It’s the “exclude from Home screen” setting in “Edit” when you click on the library.
Yee!
thank you
