Convert ISO files to MKV
What are you guys using to do this? I tried MakeMKV but when program runs get dialog MakeMKV BETA Popup saying version is too old. I download newest I believe. If hit OK to continue program closes.
Anyways what is a good program. I want to keep video/audio at original since playing back in Home Theater that supports 4K and Dolby ATMOS.
You need to update the key every couple of months, it’s still free though. Just Google MakeMkv key.
Looks like the site is down right now so get the cached version of the page.
Thanks for info. Didn’t know about the key thing. However looks like site been down for a bit. Guessing that is only way get a key?
Like I said get the cached version of the page from the google search, just click the green down arrow:
When use that key it takes it and says restart program. When I do I get the dialog box to enter it again.
The register button?
Yes. When I click it and add the key. Tell me restart program. When I do this dialog comes up again.
The key provided at the google cached page is currently working for me on makemkv version 10.1.6 until the end of Sept.
It may be you dont have the newest version of MakeMkv. You need a valid key and a fairly new version.
Probably best to wait for the site to come back up (assuming it ever does). The page now says Account Suspended.
Site is back but still having same issue. Not sure what deal is. For now going to start with using DVDFab and see how that goes. I heard Makemkv was easier and faster.
Downloaded from their so should be newest beta.
Site is back. Key is valid until end of September 2017:
https://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Make sure you have the current version, 1.10.6.
http://www.makemkv.com/download/
Any issues with your systems date/time, either in BIOS or OS?
