DKUSER
1
Server Version#: Version 1.32.8.7639
Player Version#: Version 4.127.1
I have some issues with shows that runs in mutiple countrys.
Especially Jeopardy is a pain.
Because of that I made a plexmatch file, including info about the show:
However it still adds the show as Jeopardy UK, which means i manually has to change it every time a new episode is added.
What do i do wrong?
Remove the Season: 2 in the plexmatch file since that isn’t season 2
Also I would get rid of the folder for every episode.
if you are going to take the time to make a plexmatch files I would just name the folder with the correct show name and tvdbID as well
DKUSER
4
Thank you.
I now see i put the wrong season in
I have changed that now, and also the folder to be Jeopardy!
I receive alle episoded in seperate folders, so not easy to change.
