Correct zip code for guide
Server Version#: 1.19.5.3112
Server Platform: Windows 7 Pro SP1
Server Hardware: Dell E6400, 6GB memory
Player Version#: 4.34.3
Tuner Make/Model: HomeRun SiliconDust Dual
Guide/Lineup name: Plex guide for 86409
Using XMLTV?: no
Channel number/Name: 3.1 as an example but several wrong
I live in the boonies and between 2 major broadcast areas. The Plex EPG is picking up incorrect channels so I wanted to go in and select a zip code closer to the city that has accurate listings.
I cannot find where to change the zip code. Can someone point me in the right direction?
This is a bit confusing as the HDHomeRun setup software shows all the right channels as does the DVR scan in Plex. Why can’t the EPG get it right?
Unfortunately you can’t change your zip code after the DVR is created. You must delete the existing DVR in Plex and create a new one, entering the new zip code when asked. On the next screen, you’ll get to pick your guide and set your channel mappings. At this point, if things don’t look right, you can select the previous button and try a different zip code.
Thank you for respomding.
