Cosmos Possible Worlds not showing up in Plex
So I have both seasons, have a folder called Cosmos. Put both season into this folder in there own folder, Season 1 and Season 2, But in Plex it only shows the first season and then for the last for episodes it is show that there are two files for only these last four episodes, 10-13, and if I look at them they are indeed both season 1 and season 2, episodes 1-9 for season 2 do not show anywhere even if I move them to their own folder?
https://thetvdb.com/series/cosmos-a-spacetime-odyssey
Note:
You can NOT use anything other than ‘Season 02’.
Season 02 - Possible Worlds <---- is right out <—along with any variation thereof.
Got mp4 files?:
After renaming/fiddling - Plex Dance the whole show if it refuses to cooperate:
If you continue to have problems:
Log Files - DEBUG log files - not VERBOSE.
Thank you for the reply. Adding a leading “0” to the first 9 episodes fixed it!
Has to be “Episode 01” and not “Episode 1”
