Create a share for Plex Library Directory
Worked! Amazing! Thanks a lot!
Hi all, thank you for this useful app. I recently did a backup of my Plex folder, with the Plex server turned off at the time, and got this error message:
ā€˜0 file(s) and 0 folder(s) are skipped because of their unsupported filename (or unsupported file size), and 47856 symbolic link(s) is skipped because symbolic link is not supported.’
Is this something I should be worried about?
Thanks.
I would be, and also need more details about your OS, since this do works nicely in both Suse and Windows
I’m doing this on QTS (updated to 4.4.2 today), controlled in Chrome on my windows PC. I have a backup harddrive connecting to my QNAP NAS where the QPKG is installed. The backup is done via Backup Station.
Have attached the backup log here:
RTRR-Job403.log (6.2 MB)
How is this relevant to my qpkg?
Backup Station uses the shared Plex folder that the qpkg helped create. Unless I am mistaken you can only choose a shared folder for backup in Backup Station. Hence why I am using your qpkg and then using Backup Station to backup from the folder it created.
Maybe I am going about this all wrong?
From the logs, I would say the problem is not the source, but the target
[2020/05/13 18:06:59] # WARNING: Skip the "Dev1Partition2/NAS Backup/Plex/Plex Media Server/Metadata/TV Shows/d/3576ebdde078e4d7401d00d488cc0797f9cf05d.bundle/Contents/_combined/seasons/4/episodes/18/thumbs/com.plexapp.agents.thetvdb_7f544b56f2dd6c07fb8642f58153e3377099f13a" symbolic link which is not supported by the file system!
I suspect your external drive might be formated as NTFS, and not EXT4
You are correct. I didn’t know this would cause problems?
Do you recommend formatting to EXT4 then?
That should work, I would guess
And do respond with the outcome, since this is community, so we share to the benefit for all :wink:
Hi @dane22 and all, and thanks for the work and help you are providing.
While I haven’t used the qpkg in this thread I already have a share for my server files from my qnap.
My question is this - Is there an easy way, like a scheduled task, or script of some kind (keep in mind noobish linux abilities) - that provide a ā€œone click solutionā€ (or better yet, as i said, a no click, scheduled, solution for making this backup?
I guess it’ll have to check the server for activity, shut it down if there is none, zip up the files, start the server up again, and upload the zip to a gdrive or whatever.
I’ve tried looking for something like this but no luck so far. Any chance someone here can point me in the right direction?
Thanks a bunch!
QNAP BackupStation can be used for this
@dane22: QNAP BackupStation would be in most cases now be HBS3, but it’s essentially the same
Did I mention, that I hate the cloud, and as such, did mean BackupStation :wink:
@Holger-Kuehn @dane22
Well, the cloud has it’s uses and I do think holding a backup of pms is a good use scenario. Regardless, thanks for the info, although I was unable to set it up to do things such as turn off the server before backup, or zip up the folder before backup, or keeping a set number of previous backups, and other more advanced options. This feels like something that someone must have written a script for…
