Creating library's
When I go into Plex through the website, it used to have a + to add new libraries. Then I could create a new library, like Action, Comedy, Horror, etc. and then add the folders that contained action movies, comedy movies, horror movies, etc. by clicking on the browse for media folder. Not the plus is gone and the browse for media folder is gone. If I create an Action library now, it adds ALL movies. How do I create a library from my media folders again?
This has been moved to the settings/admin section during the introduction of the new UNO user interface.
Here’s the description how to create new libraries:
https://support.plex.tv/articles/200288926-creating-libraries/
Click MORE under the Pinned Libraries on home screen, then the + is next to your Server Name
42%20AM
I followed these directions, but still, the part that says * Next, add the folders with the media files click “Browse for media folder” there is nothing that says browse for media folder to click on.
Are you using a WD MyCloud Home as your server?
You can’t add more libraries on these.
Ya I am. I had a seagate and the hard drive went out on me after a year or so. So I decided to switch the the MyCloud. I made the separate folders on it under the Plex folder and was hoping to do that on the plex library too so if I added a movie on MyCloud comedy folder it would goto the comedy library. Well That sucks. Ill just have to keep doing fix match to all my movies when they add to plex.
I don’t understand why you are doing this.
There is a file naming guide. If you stick to it, you can avoid 99% of all mismatches.
https://support.plex.tv/articles/categories/your-media/
