I installed a new plexmediaserver deb on ubuntu 16, started it up, logged in, and I can’t find the option anywhere to add a media folder anywhere. “Your Media” on the left goes, uselessly, to a page that says “download plex media server”, which is what I’m already running.
So what’s the deal? Is this completely nerfed and useless now? Or is this version just completely broken?
In order to create a new library you might need to click the More button in the navigation. In the subsequent view you can hover over the server name and click + to add a new library.
As part of the library creation dialog you’ll be asked to add one (or more) folders to this library.
If you want to add new content (folders) to an existing library… click ... > Manage Library > Edit... and add/change the folders in the Add folder tab.
Edit: If you don’t want to jump between more and pinned in the main navigation… you can always manage your libraries under Settings > [Server Name] > Manage > Libraries
There’s a “more”, but there’s no “+” anywhere. There’s no server name to hover over. There’s no manage library. Under settings I don’t have a server name anything.
