Critical error unkown when trying to launch
Trying to launch any game i’m getting critical error 15000. on just the stock games!
HERE IS A COPY OF MY LOG:
Jan 27, 2021 09:35:59.016 [0x000026b4] DEBUG - Parsec: hostname = MEDIARECORDE
Jan 27, 2021 09:35:59.016 [0x000026b4] DEBUG - Parsec: ctrl_support = 0
Jan 27, 2021 09:35:59.038 [0x000026b4] DEBUG - Unhandled env #16
Jan 27, 2021 09:35:59.038 [0x000026b4] DEBUG - Unhandled env #9
Jan 27, 2021 09:35:59.038 [0x000026b4] INFO - SYSTEM_DIRECTORY: (null)
Jan 27, 2021 09:35:59.038 [0x000026b4] DEBUG - Unhandled env #30
Jan 27, 2021 09:35:59.038 [0x000026b4] INFO - CONTENT_DIRECTORY: (null)
Jan 27, 2021 09:35:59.038 [0x000026b4] DEBUG - Asked for save directory.
Jan 27, 2021 09:35:59.038 [0x000026b4] INFO - SAVE_DIRECTORY: C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1
Jan 27, 2021 09:35:59.038 [0x000026b4] DEBUG - Setting pixel format to BGRA8888.
Jan 27, 2021 09:35:59.084 [0x000026b4] INFO - AV_INFO: width=640 height=480
Jan 27, 2021 09:35:59.084 [0x000026b4] INFO - AV_INFO: max_width=640 max_height=480
Jan 27, 2021 09:35:59.084 [0x000026b4] INFO - AV_INFO: aspect_ratio = 1.333333
Jan 27, 2021 09:35:59.084 [0x000026b4] INFO - AV_INFO: fps = 60.000000 sample_rate = 48000.000000
Jan 27, 2021 09:35:59.084 [0x000026b4] INFO - FPS reported as 60.000000.
Jan 27, 2021 09:35:59.526 [0x000026b4] DEBUG - GL Vendor graphic card: NVIDIA Corporation
Jan 27, 2021 09:35:59.526 [0x000026b4] DEBUG - GL Version: 3.1.0
Jan 27, 2021 09:35:59.526 [0x000026b4] DEBUG - GL Renderer: Quadro FX 5800/PCIe/SSE2
Jan 27, 2021 09:35:59.526 [0x000026b4] DEBUG - GL Shading language version: 1.40 NVIDIA via Cg compiler
Jan 27, 2021 09:35:59.527 [0x000026b4] DEBUG - Setting game geometry to 640x480.
Jan 27, 2021 09:35:59.530 [0x000026b4] DEBUG - Renderer: Raw aspect ratio is 1.333, desired aspect ratio is 1.333, resolution computed is 640 x 480
Jan 27, 2021 09:35:59.532 [0x000026b4] INFO - Parsec: Encoding with FPS of 60.
Jan 27, 2021 09:35:59.532 [0x000026b4] DEBUG - FPS = 60.000000, microseconds per frame: 16666.
Jan 27, 2021 09:35:59.533 [0x000026b4] INFO - Starting game:C:\Users\derreck\AppData\Local\Plex Media Server\Games\Arcade\asteroid.zip
Jan 27, 2021 09:35:59.533 [0x000026b4] DEBUG - Path extraction result: File name=C:\Users\derreck\AppData\Local\Plex Media Server\Games\Arcade\asteroid.zip
Jan 27, 2021 09:35:59.533 [0x000026b4] DEBUG - Path extraction result: Game name=asteroid
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - Path extraction result: System name=Arcade
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - Path extraction result: Game path=C:\Users\derreck\AppData\Local\Plex Media Server\Games\Arcade
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - Path extraction result: Parent path=C:\Users\derreck\AppData\Local\Plex Media Server\Games
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - Searching for driver asteroid
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - System type: ARCADE
Jan 27, 2021 09:35:59.534 [0x000026b4] INFO - Game name: asteroid, Game description: Asteroids (rev 4)
Jan 27, 2021 09:35:59.534 [0x000026b4] ERROR - System not found: Arcade
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - Searching for driver Arcade
Jan 27, 2021 09:35:59.534 [0x000026b4] WARNING - Driver Arcade not found -1
Jan 27, 2021 09:35:59.534 [0x000026b4] INFO - Creating frontend for game: asteroid
Jan 27, 2021 09:35:59.534 [0x000026b4] INFO - Softlists: 1
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - Parameters:
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - mame
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -nothrottle
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -joystick
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -joystick_deadzone
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - 0
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -joystick_saturation
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - 1
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -samplerate
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - 48000
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -nocheat
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -nomouse
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -nolightgun
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -noreadconfig
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -cfg_directory
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\mame\cfg
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -nvram_directory
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\mame\nvram
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -input_directory
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\mame\input
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -state_directory
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\mame\states
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -snapshot_directory
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\mame\snaps
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -diff_directory
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\mame\diff
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -samplepath
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - .\mame\samples
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -artpath
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - .\mame\artwork
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -cheatpath
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - .\mame\cheat
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -inipath
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - .\mame\ini
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -hashpath
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - .\mame\hash
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - -rompath
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - C:\Users\derreck\AppData\Local\Plex Media Server\Games\Arcade
Jan 27, 2021 09:35:59.534 [0x000026b4] DEBUG - asteroid
Jan 27, 2021 09:35:59.688 [0x000026b4] INFO - SOURCE FILE: …/…/…/…/…/src/mame/drivers/asteroid.cpp
Jan 27, 2021 09:35:59.688 [0x000026b4] INFO - PARENT: 0
Jan 27, 2021 09:35:59.688 [0x000026b4] INFO - NAME: asteroid
Jan 27, 2021 09:35:59.688 [0x000026b4] INFO - DESCRIPTION: Asteroids (rev 4)
Jan 27, 2021 09:35:59.688 [0x000026b4] INFO - YEAR: 1979
Jan 27, 2021 09:35:59.688 [0x000026b4] INFO - MANUFACTURER: Atari
Jan 27, 2021 09:35:59.688 [0x000026b4] DEBUG - Unhandled env #65587
Jan 27, 2021 09:35:59.814 [0x000026b4] INFO - RES:1
Jan 27, 2021 09:35:59.814 [0x000026b4] INFO - MAIN FIRST
Jan 27, 2021 09:35:59.830 [0x000026b4] INFO - AV_INFO: width=640 height=480
Jan 27, 2021 09:35:59.831 [0x000026b4] INFO - AV_INFO: max_width=640 max_height=480
Jan 27, 2021 09:35:59.831 [0x000026b4] INFO - AV_INFO: aspect_ratio = 1.333333
Jan 27, 2021 09:35:59.831 [0x000026b4] INFO - AV_INFO: fps = 61.523438 sample_rate = 48000.000000
Jan 27, 2021 09:35:59.831 [0x000026b4] DEBUG - Setting game geometry to 640x480.
Jan 27, 2021 09:35:59.834 [0x000026b4] DEBUG - Renderer: Raw aspect ratio is 1.333, desired aspect ratio is 1.333, resolution computed is 640 x 480
Jan 27, 2021 09:35:59.836 [0x000026b4] INFO - Parsec: Encoding with FPS of 61.
Jan 27, 2021 09:35:59.836 [0x000026b4] INFO - ChangeAV: w:640 h:480 ra:1.333333.
Jan 27, 2021 09:35:59.836 [0x000026b4] INFO - OpenGL: Refreshing vertex data.
Jan 27, 2021 09:35:59.836 [0x000026b4] DEBUG - OpenGL: Using scale factor 1.0 x 1.0.
Jan 27, 2021 09:36:01.273 [0x00002850] DEBUG - Parsec: net = SCTP|::ffff:192.168.0.29|55368
Jan 27, 2021 09:36:01.329 [0x00002c9c] INFO - Parsec: * encode_init[118] = -15101
Jan 27, 2021 09:36:01.329 [0x00002c9c] INFO - Parsec: * amf_init/LoadLibrary[184] = 0
Jan 27, 2021 09:36:01.335 [0x00002c9c] INFO - Parsec: * mfxe_init/MFXInit[241] = -3
Jan 27, 2021 09:36:01.335 [0x00002c9c] INFO - Parsec: * encode_init[118] = -15007
Jan 27, 2021 09:36:01.336 [0x00000540] INFO - Parsec: * host_msg_thread_cleanup[1825] = -15000
Jan 27, 2021 09:36:01.341 [0x000026b4] DEBUG - Custom message: 2
Jan 27, 2021 09:36:02.887 [0x000026b4] DEBUG - Got WM_USER message, exiting.
Jan 27, 2021 09:36:02.913 [0x000026b4] INFO - Game needs at most 70218 bytes to serialize.
Jan 27, 2021 09:36:02.922 [0x000026b4] INFO - Serialization success to C:\Users\derreck\AppData\Local\Plex Media Server\Game Saves\3\546a50a6fdfd1659d986686319cd15fc3428d29\1\Snapshot.dat.
Jan 27, 2021 09:36:02.922 [0x000026b4] DEBUG - Serialization not required for RAM.dat.
Jan 27, 2021 09:36:02.922 [0x000026b4] DEBUG - Serialization not required for RTC.dat.
Jan 27, 2021 09:36:03.036 [0x000026b4] DEBUG - Exiting.
Same
A critical error occurred.
Error code: -15000 (Unknown)
A 15000 error typically means you do not have a compatible GPU. Check against this https://support.parsec.app/hc/en-us/articles/360001106411-How-Do-I-Know-If-My-Graphics-Card-Supports-Hosting-A-Game-With-Parsec.
This Error 15000 is pretty much is a deal-killer for me. I have a Mac Pro Tower maxed out with dual 6-core CPUs, 48GB RAM, and an AMD Radeon RX-580 GPU running macOS Mojave and still can’t host a minuscule 1970s ROM on this system. This is pretty disappointing to say the least, as outside of my Plex system, I can run thousands of MAME arcade games without issue all the way up to the latest years. And, I can just about do the same with my Raspberry Pi. Tried other native Plex clients on iOS and Apple TV and only get a black screen.
Same Here i have a Ryzen 7 2700, I can run Psx emulation fine but according to this my GPU isn’t strong enough to run ChronoTrigger on the snes ?? which run fine outside of plex btw…
I believe that is a supported GPU. Please check that the driver is updated.
That’s a CPU. What GPU do you have?
I’m on a Mac. There are no specific drivers to add outside of the latest Mojave, which I’m on. If I can’t get this to work before my free trial is over, I’m ditching it and not coming back. No way am I paying for a half-baked feature. This is essentially a public beta.
Radeon HD 7770 is what is installed… it shows to be compatible in the list.
Radeon HD 6800
same, start hearing a retro beep and then it shuts down with “A critical error occurred. Error code: -15000 (Unknown)”
Mac Mini 2010 NVIDIA GeForce 320M 256 MB. I guess this means unsupported? Should’ve checked before wasting my 1 week trial, but I was under the impression all Macs worked.
Same here on iMac late 2015 27" - Mojave, Plex running fine for years. Added Game arcade signed up, everything followed I get nothing but a black screen on my devices with white controllers drawn on screen. Never anything else. Oddly the saved thumbnails show game in progress as if I was playing.
Failed to load core: dlopen(~/Library/Application Support/Plex Media Server/Game Cores/mame_libretro.dylib, 6): no suitable image found.
it’s possible we can support more Mac hardware by using software encoding. there is only limited support for hardware encoding via Parsec.
Does that mean I should give up trying and cancel my trial for Arcade? I love a challenge but not having any luck.
This being the case, it should be a free feature for PlexPass subscribers. How difficult would it be to just implement the cores yourselves and not use Parsec? The code is open source! My friend can’t even get it to work on his Windows box either.
we can’t do that because of the licensing we have around Parsec and the Atari games which entail per-user costs.
the “cores” are emulators; Parsec is the low-latency streaming library.
Why is parsec required for local LAN play?
Why not just provide a hook into the games for plex and let users optional install and “license” items they want to add.
because that’s the architecture. otherwise we’d need to build all emulators into all our apps.
i don’t understand the question. you can add any cores you want.
https://support.parsec.app/hc/en-us/articles/115002624051-Error-Codes-22006-and-15000-Unable-To-Initialize-Encoder-On-Your-Server-
but if you are simply using Parsec for remote emulation, surely you could just opt for local emulators on the plex server and then stream those? Maybe I’m misunderstanding what exactly it is that Parsec does but if all it is doing is handling remote emulation and passing it back to plex it would make more sense to handle the emulation locally and reduce bandwidth requirement? Parsec cant be doing much if it is requiring a decent GFX card in the local machine to handle the rendering
