CSI Immorality naming for TV SPECIAL
CSI Crime Scene Investigation (2000)
folder under that I have SPECIALS and I put the csi immorality special movie in there
named: from The TVDB
CSI Crime Scene Investigation - Special 1 - Immortality
CSI Crime Scene Investigation - Special 2 - Immortality
however when I do the plex dance, no SPECIAL folder shows up
I use FILEBOT to name of TV and MOVIES
What am I doing wrong??
Naming should be like this:
TV Shows   <- the folder linked to your tv-show library
    Specials   <- you can also use "Season 00"
      CSI Crime Scene Investigation (2000) - s00e02 - Immortality.ext
Where .ext is a placeholder for your actual file extension. The episode title in the file name is completely optional!
TheTVDb considers this to be a single special/episode. So if you have it split into 2 files you have 2 options:
  1. merge both files using e.g. MKVToolNix
  2. use the naming schema to “stack” files
    CSI Crime Scene Investigation (2000) - s00e02 - Immortality - pt1.ext
    CSI Crime Scene Investigation (2000) - s00e02 - Immortality - pt2.ext
