ANyone know if there are any issues with the most recent release of the Plex Server App for windows?
I'm running Win 7 Home.
I've been running plex for a LONG time now and usually keep it up to date. So just last night finally decided to install the new server.
Downloaded the file, installed the new server, no errors, everything seemed ok, until we decided to watch something on our Roku.
The library never loads, it just sits there......
So I decided to check my PC. I loaded the Plex software on my PC and same thing, the library never loads.
SO I right clicked on the server icon on the taskbar, clicked media manager.... it brings up the broswer, but then that just sits and sits and never loads...
So I decided to uninstall and reinstall the server app.... it does the same thing....
I then decided to load the older version.... sadly I deleted the installer for that at some point, so went to the downlaods page and see that unless I'm a Plexpass member I can't download older versions.... ok.....
After that, and much testing and trying I finally went into system restore, and restored to a restore point before I installed the never version.... Now when windows loads, the Plex Server App briefly loads, and then crashes, every time. No error messages mind you, the icon appears in the taskbar and then goes away. I check the running process and services etc, and it's not there.
Can anyone help?
Like I said, I never get any installation errors, it appears to install just fine,
