I'm getting a 404 error. When I first set it up it worked great then it just stopped. Tried deleting caches, frame/system bundles. No one I know that uses Plex has any clue what could be wrong. :(
Dec 03, 2014 22:05:18:735 [3240] INFO - LANGID = 0x409
Dec 03, 2014 22:05:18:772 [3240] INFO - Windows version: 6.1 (Build 7601)
Dec 03, 2014 22:05:18:772 [3240] INFO - 6 3214 MHz processor(s): Architecture=0, Level=16, Revision=2560
Dec 03, 2014 22:05:18:772 [3240] INFO - PROCESSOR_IDENTIFIER=AMD64 Family 16 Model 10 Stepping 0, AuthenticAMD
Dec 03, 2014 22:05:18:773 [3240] INFO - Plex Media Server v0.9.11.4.739-a4e710f - Microsoft PC - build: windows-i386 english
Dec 03, 2014 22:05:18:773 [3240] DEBUG - Opening 20 database sessions to library, SQLite 3.8.6, threadsafe=1
Dec 03, 2014 22:05:18:865 [3240] DEBUG - Running migrations.
Dec 03, 2014 22:05:18:865 [3240] DEBUG - Running 5 database fix-ups.
Dec 03, 2014 22:05:19:774 [3240] DEBUG - Listening on port 32400 with queue of 2147483647 connections.
Dec 03, 2014 22:05:19:774 [3240] DEBUG - Listening on port 32401 with queue of 2147483647 connections.
Dec 03, 2014 22:05:20:326 [3240] DEBUG - Setting up scheduled updates
Dec 03, 2014 22:05:20:326 [3240] INFO - LibraryUpdateManager path watching is disabled
Dec 03, 2014 22:05:20:327 [3048] DEBUG - Starting scheduled updates, every 3600 seconds
Dec 03, 2014 22:05:20:332 [3240] DEBUG - Installing plug-in: Framework
Dec 03, 2014 22:05:23:865 [4676] DEBUG - Crash Reporter: Starting up.
Dec 03, 2014 22:05:31:106 [3240] DEBUG - Installing plug-in: System
Dec 03, 2014 22:05:32:105 [4796] DEBUG - File C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins changed: -1 => 1417662331.
Dec 03, 2014 22:05:32:105 [4796] DEBUG - Scanning for plug-ins in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins
Dec 03, 2014 22:05:32:106 [4796] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\System.bundle.
Dec 03, 2014 22:05:32:107 [4796] DEBUG - [com.plexapp.system] Setting plug-in to always running (daemon mode).
Dec 03, 2014 22:05:32:109 [4796] DEBUG - Starting file watcher for com.plexapp.system
Dec 03, 2014 22:05:32:109 [4796] DEBUG - Plugin::createProcess: Creating plugin process: "C:\Program Files (x86)\Plex\Plex Media Server\PlexScriptHost.exe" "C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle\Contents\Resources\Versions\2\Python/bootstrap.py" "C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\System.bundle"
Dec 03, 2014 22:05:32:110 [4796] DEBUG - Spawned plug-in com.plexapp.system with PID 3380
Dec 03, 2014 22:05:32:110 [4796] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
Dec 03, 2014 22:05:36:711 [4796] DEBUG - Reading 486 bytes in the body, code is 200
Dec 03, 2014 22:05:36:711 [4796] DEBUG - [com.plexapp.system] Plug-in running on port 49634.
Dec 03, 2014 22:05:36:711 [4796] DEBUG - * Plug-in handles prefix: /system
Dec 03, 2014 22:05:36:711 [4796] DEBUG - * Plug-in handles prefix: /player
Dec 03, 2014 22:05:36:711 [4796] DEBUG - Read configuration for [com.plexapp.system], had 2 prefixes
Dec 03, 2014 22:05:36:790 [4796] DEBUG - Done with 1 synchronous plug-in starts, starting the rest in parallel.
Dec 03, 2014 22:05:36:790 [4796] DEBUG - Updating the list of agents known by the system.
Dec 03, 2014 22:05:36:790 [4796] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/agents
Dec 03, 2014 22:05:36:790 [3240] DEBUG - Image transcode cache directory: C:\Users\Mediabox\AppData\Local\Plex Media Server\Cache\PhotoTranscoder
Dec 03, 2014 22:05:36:791 [4796] DEBUG - HTTP requesting to: http://127.0.0.1:49634/system/agents
Dec 03, 2014 22:05:36:791 [3240] DEBUG - Cleaning old transcode directories.
Dec 03, 2014 22:05:36:814 [3240] DEBUG - MyPlex: Updating device connections (from timer: 0)
Dec 03, 2014 22:05:36:815 [3240] DEBUG - HTTP requesting to: https://plex.tv/devices/65492e00832b4e9747ac013cbdd1c2e87239f15b?Connection[][uri]=http://192.168.1.10:32400&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Dec 03, 2014 22:05:37:243 [3240] DEBUG - NAT: Starting Mapping Thread.
Dec 03, 2014 22:05:37:243 [3240] DEBUG - NAT: Using manually specified port of 32400.
Dec 03, 2014 22:05:37:243 [3240] DEBUG - NAT: Creating NAT puncher thread 03F5DA78
Dec 03, 2014 22:05:37:243 [3240] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 03, 2014 22:05:37:243 [1028] DEBUG - NAT: Updating mapping in puncher thread 03F5DA78
Dec 03, 2014 22:05:37:243 [1028] DEBUG - NAT: Creating puncher.
Dec 03, 2014 22:05:37:243 [1028] DEBUG - NAT: Switching to NAT-PMP strategy.
Dec 03, 2014 22:05:37:243 [1028] DEBUG - NAT: Creating NATPmPPuncher.
Dec 03, 2014 22:05:37:243 [3764] DEBUG - HTTP requesting to: https://plex.tv/users/account.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Dec 03, 2014 22:05:37:244 [1028] DEBUG - NAT: Initializing NAT-PMP, success=1
Dec 03, 2014 22:05:37:244 [1028] DEBUG - NAT: Finding public address failed the first way, switching.
Dec 03, 2014 22:05:37:244 [1028] DEBUG - NAT: Switching to UPnP strategy.
Dec 03, 2014 22:05:37:244 [1028] DEBUG - NAT: Creating NATUPnPPuncher.
Dec 03, 2014 22:05:37:248 [3240] DEBUG - Network interfaces:
Dec 03, 2014 22:05:37:248 [3240] DEBUG - * 1 {846EE342-7039-11DE-9D20-806E6F6E6963} (127.0.0.1) (loopback: 1)
Dec 03, 2014 22:05:37:248 [3240] DEBUG - * 10 {7BBDC2E5-DAF8-40CB-BF28-0EF229B4E9D5} (192.168.1.10) (loopback: 0)
Dec 03, 2014 22:05:37:252 [3240] DEBUG - MyPlex: Last published value didn't change, we're done.
Dec 03, 2014 22:05:37:252 [3240] DEBUG - Creating NetworkServices singleton.
Dec 03, 2014 22:05:37:252 [3240] DEBUG - NetworkServices: Initializing...
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 040ED3B0: Creating new Network Service and registering for notifications.
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 040ED3B0: NetworkService got notification of changed network (first change: 1)
Dec 03, 2014 22:05:37:253 [3240] DEBUG - NetworkService: Quick dispatch of network change.
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 04121D90: Creating new Network Service and registering for notifications.
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 04121D90: NetworkService got notification of changed network (first change: 1)
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 04123DD0: Creating new Network Service and registering for notifications.
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 04123DD0: NetworkService got notification of changed network (first change: 1)
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 040DEA40: Creating new Network Service and registering for notifications.
Dec 03, 2014 22:05:37:253 [3240] DEBUG - 040DEA40: NetworkService got notification of changed network (first change: 1)
Dec 03, 2014 22:05:37:253 [3088] DEBUG - Network change for advertiser.
Dec 03, 2014 22:05:37:253 [3088] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32414 (outbound: 0)
Dec 03, 2014 22:05:37:253 [3240] DEBUG - Starting HTTP server.
Dec 03, 2014 22:05:37:253 [3240] DEBUG - Running server...
Dec 03, 2014 22:05:37:254 [3556] DEBUG - DLNA server starting.
Dec 03, 2014 22:05:37:254 [3556] DEBUG - Job running: C:\Program Files (x86)\Plex\Plex Media Server\PlexDlnaServer.exe
Dec 03, 2014 22:05:37:254 [3240] DEBUG - Waiting for server condition to be signaled.
Dec 03, 2014 22:05:37:254 [0308] DEBUG - Set up a thread pool for HTTP server with 2 threads.
Dec 03, 2014 22:05:37:254 [0308] DEBUG - Running database fix-ups.
Dec 03, 2014 22:05:37:254 [3088] DEBUG - Network change for advertiser.
Dec 03, 2014 22:05:37:254 [3088] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32410 (outbound: 0)
Dec 03, 2014 22:05:37:254 [3088] DEBUG - NetworkService: Network change for browser (polled=0), closing 0 browse sockets.
Dec 03, 2014 22:05:37:254 [3088] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32413 (outbound: 0)
Dec 03, 2014 22:05:37:254 [3088] DEBUG - NetworkService: Browsing on interface 127.0.0.1 on broadcast address 127.255.255.255 (index: 0)
Dec 03, 2014 22:05:37:255 [0308] DEBUG - Database Fixups: Destroyed 0 transient items.
Dec 03, 2014 22:05:37:255 [3088] DEBUG - NetworkService: Browsing on interface 192.168.1.10 on broadcast address 192.168.1.255 (index: 1)
Dec 03, 2014 22:05:37:255 [0308] DEBUG - Running database fix-ups completed in 0.0 seconds.
Dec 03, 2014 22:05:37:255 [3088] DEBUG - NetworkService: Network change for browser (polled=1), closing 0 browse sockets.
Dec 03, 2014 22:05:37:255 [3088] DEBUG - NetworkService: Browsing on interface 127.0.0.1 on broadcast address 127.255.255.255 (index: 0)
Dec 03, 2014 22:05:37:263 [3088] DEBUG - NetworkServiceBrowser: SERVER arrived: 127.0.0.1 (Teletraan[ONE])
Dec 03, 2014 22:05:37:263 [3088] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=127.0.0.1
Dec 03, 2014 22:05:37:263 [3088] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/notify/serverUpdated?host=127.0.0.1
Dec 03, 2014 22:05:37:263 [3088] DEBUG - HTTP requesting to: http://127.0.0.1:49634/system/notify/serverUpdated?host=127.0.0.1
Dec 03, 2014 22:05:37:274 [3088] DEBUG - [com.plexapp.system] HTTP reply status 500, with 2891 bytes of content.
Dec 03, 2014 22:05:37:616 [5040] DEBUG - Sync: myPlexSignIn
Dec 03, 2014 22:05:37:616 [3764] DEBUG - EventSource: Creating.
Dec 03, 2014 22:05:37:616 [3764] DEBUG - EventSource: Connecting to pubsub.plex.tv
Dec 03, 2014 22:05:37:622 [3764] DEBUG - MyPlex: Last published value didn't change, we're done.
Dec 03, 2014 22:05:37:631 [2964] DEBUG - It took 0.000000 sec to serialize a list with 1 elements.
Dec 03, 2014 22:05:37:631 [2964] DEBUG - MyPlex: Sending Server Info to myPlex (user=rlchaneyjr@gmail.com, ip=, port=32400)
Dec 03, 2014 22:05:37:721 [3764] DEBUG - HTTP requesting to: https://plex.tv/devices/65492e00832b4e9747ac013cbdd1c2e87239f15b/certificate?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Dec 03, 2014 22:05:37:721 [2964] DEBUG - HTTP requesting to: https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Dec 03, 2014 22:05:37:769 [4164] DEBUG - EventSource: Resolved to 108.168.178.53
Dec 03, 2014 22:05:37:880 [4164] DEBUG - EventSource: Connected.
Dec 03, 2014 22:05:37:880 [2488] DEBUG - EventSource: Wrote data, reading reply.
Dec 03, 2014 22:05:38:228 [2964] DEBUG - MyPlex: Published Mapping State response was 422
Dec 03, 2014 22:05:38:228 [2964] WARN - MyPlex: Invalid response when mapping state (code=422):
Dec 03, 2014 22:05:38:285 [2488] DEBUG - EventSource: Read HTTP reply header.
Dec 03, 2014 22:05:40:163 [4796] DEBUG - [com.plexapp.system] HTTP reply status 200, with 5773 bytes of content.
Dec 03, 2014 22:05:40:165 [4796] DEBUG - The system knows about 11 agents.
Dec 03, 2014 22:05:40:166 [2640] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\Framework.bundle.
Dec 03, 2014 22:05:40:166 [3284] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\HTbackdrops.bundle.
Dec 03, 2014 22:05:40:166 [3584] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\IMDB.bundle.
Dec 03, 2014 22:05:40:166 [4796] DEBUG - Waiting for all 18 plug-ins to finish starting.
Dec 03, 2014 22:05:40:167 [2640] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\LastFM.bundle.
Dec 03, 2014 22:05:40:167 [3284] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.htbackdrops] yet.
Dec 03, 2014 22:05:40:167 [3284] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\LocalMedia.bundle.
Dec 03, 2014 22:05:40:167 [3584] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.imdb] yet.
Dec 03, 2014 22:05:40:167 [3584] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\Media-Flags.bundle.
Dec 03, 2014 22:05:40:168 [2640] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.lastfm] yet.
Dec 03, 2014 22:05:40:168 [2640] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\MoviePosterDB.bundle.
Dec 03, 2014 22:05:40:168 [3584] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\OpenSubtitles.bundle.
Dec 03, 2014 22:05:40:169 [3284] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.localmedia] yet.
Dec 03, 2014 22:05:40:169 [3284] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\PersonalMedia.bundle.
Dec 03, 2014 22:05:40:169 [2640] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.movieposterdb] yet.
Dec 03, 2014 22:05:40:169 [2640] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\PlexThemeMusic.bundle.
Dec 03, 2014 22:05:40:169 [3584] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.opensubtitles] yet.
Dec 03, 2014 22:05:40:169 [3584] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\Scanners.bundle.
Dec 03, 2014 22:05:40:170 [3584] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\Services.bundle.
Dec 03, 2014 22:05:40:170 [3284] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.none] yet.
Dec 03, 2014 22:05:40:170 [3284] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\SiteConfigurations.bundle.
Dec 03, 2014 22:05:40:170 [2640] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.plexthememusic] yet.
Dec 03, 2014 22:05:40:170 [2640] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\The-Movie-Database.bundle.
Dec 03, 2014 22:05:40:170 [3584] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\TheTVDB.bundle.
Dec 03, 2014 22:05:40:170 [3284] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\WebClient.bundle.
Dec 03, 2014 22:05:40:171 [2640] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.themoviedb] yet.
Dec 03, 2014 22:05:40:171 [2640] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\WebManager.bundle.
Dec 03, 2014 22:05:40:171 [3284] DEBUG - Starting plug-in C:\Users\Mediabox\AppData\Local\Plex Media Server\Plug-ins\Wikipedia.bundle.
Dec 03, 2014 22:05:40:171 [3584] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.thetvdb] yet.
Dec 03, 2014 22:05:40:172 [3284] DEBUG - Perfect cache hit, we don't need to start [com.plexapp.agents.wikipedia] yet.
Dec 03, 2014 22:05:40:256 [4676] DEBUG - Device: Microsoft PC
Dec 03, 2014 22:05:40:259 [1028] DEBUG - NAT: Initialized UPnP, result: SUCCESS
Dec 03, 2014 22:05:40:261 [1028] DEBUG - NAT: Requested public address via UPnP (success=1)
Dec 03, 2014 22:05:40:261 [1028] DEBUG - NAT: Obtained public address of 98.209.165.251 (failed: 0 myPlex: 0).
Dec 03, 2014 22:05:40:261 [1028] DEBUG - NAT: Checking for change in address: old was and new is 98.209.165.251.
Dec 03, 2014 22:05:40:261 [1028] INFO - NAT: Mapping changed 98.209.165.251:32400 -> 192.168.1.10:32400
Dec 03, 2014 22:05:40:267 [5040] WARN - Sync: Couldn't get sync lists without subscription.
Dec 03, 2014 22:05:40:267 [4796] DEBUG - Done waiting for all plug-ins to start.
Dec 03, 2014 22:05:40:271 [1028] DEBUG - It took 0.001000 sec to serialize a list with 1 elements.
Dec 03, 2014 22:05:40:271 [1028] DEBUG - MyPlex: Sending Server Info to myPlex (user=rlchaneyjr@gmail.com, ip=, port=32400)
Dec 03, 2014 22:05:40:272 [1028] DEBUG - HTTP requesting to: https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Dec 03, 2014 22:05:40:761 [1028] DEBUG - MyPlex: Published Mapping State response was 422
Dec 03, 2014 22:05:40:761 [1028] WARN - MyPlex: Invalid response when mapping state (code=422):
Dec 03, 2014 22:05:40:779 [1028] DEBUG - MyPlex: Last published value didn't change, we're done.
Dec 03, 2014 22:05:40:779 [1028] DEBUG - NAT: Updating mapping complete in thread 03F5DA78.
Dec 03, 2014 22:05:40:779 [1028] DEBUG - NAT: Deleting puncher.
Dec 03, 2014 22:05:40:779 [1028] DEBUG - NAT: Deleting NATUPnPPuncher.
Dec 03, 2014 22:05:40:779 [1028] DEBUG - NAT: Deleting NATPmPPuncher.
Dec 03, 2014 22:05:40:782 [1028] DEBUG - NAT: We're going to next poll in 1.0 hours.
