Deleting items from Plex DVR
When setting up a tuner on the Plex DVR, it does not allow me to store files other than monitored libraries. I use MCE Buddy to convert the ts file to something that all my devices can handle (I settled on MKV). After it is done, it deletes the original file. It would be nice if Plex was only monitoring the directory that MCE Buddy was placing the completed file, rather than the location the tuner deposited the original.
The end result is that I can watch the new entry, but I cant delete it using the Plex interface. It can’t find the file to delete it.
I believe you should be able to accomplish that with a post processing script.
