I have 1,331 film files, consisting of:
- MKV (1,303)
- AVI (16)
- MP4 (11)
- M4V (1)
Plex shows only 1,320 films.
How can I find out which 11 are missing?
MP4 - 11
11 files missingâŚhmmmmm
First, make sure your Movies follow PRECISELY this guide:
https://support.plex.tv/articles/categories/your-media/
Then, Under ALL tabs in Shows and Movies - do this:
Move LMA to the bottom of the stack of active agents:
Red: where it was
Green: where it goes
Rescan, Refresh Metadata, or Plex Dance:
Also take a look at the unmatched and duplicates filters (example below) for your movie library
I donât fully understand your post.
These are my equivalent current settings:
Iâve tried Scan Library Files and nothing changes.
I donât believe forcing a full refresh (clear and start again) will match the final 11 film files.
Is there an âerror logâ of sorts, that can help me identify them?
That did it!
Thank you ![]()
Yea I wouldnât spend ton time on the PD. Check via filters first as mentioned previously. Dupes and untagged. Worst case you can install plex tools plugin that looks for missing media. My guess is the filters will shed some light.
Itâs right for Plex Movie.
How 'bout The Movie Database?
How 'bout Shows?
The reason:
with LMA in itâs default position - at the top - gives Plex full authority to IGNORE your MP4 file names in favor of bogus embedded title fields - that WILL NOT match, or possibly even be recognized by Plex.
You DO need LMA - just not at the top.
You DO need to DEMOTE LMA everywhere it will matter and thatâs under ALL tabs in Shows and Movies.
If you have Movies that arenât even in the database - the ONLY way youâre going to get them in the database is:
Rescan
Refresh Metadata <âhard to do if Plex hasnât seen the movie yet.
Plex Dance - fix the names, move LMA, Plex Dance to create a brand new bundle - hopefully with the right stuff in it this time.
Note:
The ONLY way Plex can identify your files is by their file names (once LMA has been DEMOTED). If your file names are such they canât be recognized by Plex and the online databases, the ONLY way to fix that is by naming/structuring your files correctly. Even if they donât match - theyâll at least be visible and you can Fix Match, or Match, or Unmatch.
Good news.
I assume you mean WebTools?
Correct, meant to say web tools.
There it is, find media. works really well for finding unidentified files.
