I was in the middle of a movie, two nights ago and Plex Media Server cut out on my Samsung Smart TV, so I checked all of my other computers, phones, and tablets, and the only one able to connect is the web browsers on the desktop computer I’m running PMS on. Every other device and computer says “Offline” or “Unable to Connect”
All of my devices are able to access media files over the network to play in VLC.
I’ve satisfied all of the General Troubleshooting.
Ensure you have the current version of Plex Media Server installed
-Yes. The web app says that it is on the current version 1.10.1.4602
Ensure that Plex Media Server is actually actively running
-Yes. I see it in the tray
Verify that your Server is listed on your Devices page
-Yes. All of my devices (PS4, Samsung TV, IOS and Android)
Disable any VPN on your computer or router
-No VPN
Disable any proxies being used on your computer or router
-No Proxies
Make sure you aren’t requiring secure connections on the server while using an app that doesn’t support them (see below)
-Yes. It’s “Disabled”.
Once you’ve checked those:
Sign out of your Plex account in both the app and Plex Media Server
-Yes.
Sign in to Your Plex Account in the Server
-Yes
Then sign into your account in the Plex app
-Yes
All Subnet Masks are the same.
I don’t use remote access, either.
Any help would be greatly appreciated. Thank you.
