Different number of movies depending on sort order
Server Version#: 1.24.3.5033
I have a Movies library with the new Plex agent. I have 2150 movies in the Windows folder, however on Plex if I sort the library by title, I have 2149, and if I sort by date added, I have 2147. Nothing in the duplicated or unmatched category, and nothing in the Trash.
What could be going on? Thanks in advance :slight_smile:
Empty collections perhaps?
The state of the Collections display option would explain the ‘by Title’ difference, but I don’t think it explains the ‘by Date Added’ difference, unless there’s something I don’t know.
Thanks both. The discrepancy between date added and title was indeed down to collections, so thank you, although it still doesn’t really describe it as the collections only had 1 item in them, but removing them seemed to have cured it.
There are still 2 items that are in the folder that aren’t in the Plex library. What’s the best way to identify them? They aren’t in the unmatched or duplicates section.
In those cases it’s usually a mismatch.
I think the usual process is to start with the Plex Dance and then go from there so that if it was a mismatch (identified as the wrong movie) when you do the dance and re-add to your library those two should be the two newest additions which should make it easier to identify if a mismatch.
