Server Version#: 1.24.3.5033, Docker on Synology DS918+
Player Version#: Windows, 1.34.1.2590-74ea7099 but does not really matter
Hey everyone,
Yes, I know, another topic about Doctor Who… But I did not find any matching my particular parameters and problem.
So I got the following file structure
-TV-Serie
+-Doctor Who (1963) {tvdb-76107}
++-Season 18
+++-s18e01.mkv
+-Doctor Who (2005) {tvdb-78804}
++-Season 1
+++-s01e01.mkv
So, I have the first airing year of the series and also the ID from TheTVDB. But Plex insists to display them in one Doctor Who entry.
I already tried to use both the “Plex TV Series” scanner as well as “Plex Series Scanner”. But I do not get two seperate entries so I also have no chance to manually fix the assignments or the metadata.
Would appreaciate someone shedding some light on my problem.
In the properties of your tv show library, on the “Add folders” tab, are you adding the folder for each show separately?
Or did you point Plex only to the parent folder TV-serie?
Only the latter can work.
