Doctor Who (1963) not differentiated from Doctor Who (2005)
Server Version#: 4.12.3
I am having a problem with Doctor who videos. TheTVdb differentiates between ‘Doctor Who’ (starting 1963, 26 seasons, ended) and ‘Doctor Who (2005)’ (currently 11 seasons), but Plex is not separating these two and so I only have ‘Doctor Who’ listed, with seasons 1-11 episodes being doubled-up. There is no option to Split videos as there is with Movies, so I cannot manually correct this.
I would greatly appreciate any help with this, or if someone has a workaround for this particular case.
  • Warren
This comes up periodically, use the forum search to find how to resolve.
Failing that, post the complete folder structure and file names for each series — hopefully you’re at least including (YEAR) in both series.
Ok, I have searched the forums (I apologize for not having done this first, I was already posting a different question, and went ahead and posted this one), and attempted the offered solution, which was to rename the files. In the screen shots, you can see that I have done this with one episode, Rose. I then Matched Doctor Who in Plex to Doctor Who [1963] and Rescan. The result is the same: while all the 1963 titles show up properly, the 2005 titles are overlapped within the corresponding directories, including the renamed Rose episode.
Rename everything properly. And then do the The Plex Dance ™
Okay, I’ll give that a try, but I am uncertain what steps 3 (empty trash) and 4 (clean bundles) mean?
Per that post did you read:
Support article: Library Actions
Okay, yes, I found how to empty trash, but I still didn’t find about cleaning bundles, even after searching…
I think it has been replaced by Refresh All Metadata, oops! You’ll find it via Manage Library:
No It’s still there.
Perhaps different OS? I’m on Windows, and mine looks like darcilicious’ screenshot.
Anyway, doing the Dance worked! Thanks for your help!!
Ah at the server level, that makes sense!
Go to More and your server Avatar, click on the Vertical Ellipsis
Ah, I see it now! Thank you!
