Dolby vision issue
Server Version#:1.41.0.8994
i have no clue why the dolby vision stopped working. it isnt working anywhere not on my iphone, laptop or my tv.
these files used to work.
they are profile 5 and profile 7 DV. but they arent working anymore.
plex isnt even recognizing them as DV.
Im also receiving this error for DV shows
when playing on Web: File is unplayable. DoVi (Profile 5) color space is not supported.
and when played on a different device through the plex app all colors are completely wrong
File info from MediaInfo
mp4:
D : 1
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
HDR format : Dolby Vision, Version 1.0, Profile 5, dvhe.05.03, BL+RPU, no metadata compression
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 41 min 10 s
Bit rate : 8 556 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Active height : 817 pixels
Active display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.172
Stream size : 2.46 GiB (93%)
Title : 265:fmt=265:moovts=-1:fps=24:deps:par=auto:colr=nclx,2,2,2,1:xps_inband:sopt:dv_profile=5@GPAC2.5-DEV-rev8346-gb21409c7a-HEAD
Color range : Full
Codec configuration box : hvcC+dvcC
