Hi all, i have ATV3 latest firmware, and windows 7 on my pc, my ATV on Trailer show all movie without image, and if i play a movie i have every time progressbar but dont play movie.
Someone know how i can fix this problem?
Thank's all
Thank's all
more info needed...
In my atv3 i changed my dns as pc ip, when i start plexconnect:
23:20:09 WebServer: ***C:\PlexConnect>PlexConnect.py
23:20:08 PlexConnect: ***
23:20:08 PlexConnect: PlexConnect
23:20:08 PlexConnect: Press CTRL-C to shut down.
23:20:08 PlexConnect: started: 23:20:08
23:20:08 PlexConnect: IP_self: 192.168.0.10
23:20:08 DNSServer: started: 23:20:08
23:20:08 DNSServer: ***
23:20:08 DNSServer: DNSServer: Serving DNS on 192.168.0.10 port 53.
23:20:08 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.
168.0.10
23:20:08 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
23:20:08 DNSServer: forward other to higher level DNS: 8.8.8.8
23:20:08 WebServer: started: 23:20:08
23:20:08 WebServer: ***
23:20:08 WebServer: WebServer: Serving HTTP on 192.168.0.10 port 80.
23:20:09 WebServer: started: 23:20:09
23:20:09 WebServer: WebServer: Serving HTTPS on 192.168.0.10 port 443.
settings.py
g_settings = { \
'enable_plexgdm' : ('True', 'False'), \
'ip_pms' : ('192.168.0.10',), \
'port_pms' : ('32400',), \
'enable_dnsserver' : ('True', 'False'), \
'port_dnsserver' : ('53',), \
'ip_dnsmaster' : ('8.8.8.8',), \
'prevent_atv_update' :('True', 'False'), \
'enable_plexconnect_autodetect' : ('True', 'False'), \
'ip_plexconnect' : ('192.168.0.10',), \
'port_webserver' : ('80',), \
'enable_webserver_ssl' : ('True', 'False'), \
'port_ssl' : ('443',), \
'certfile' : ('c:\PlexConnect\assets\certificates railers.pem',), \
'loglevel' : ('Normal', 'High', 'Off'), \
'logpath' : ('.',), \
settings.cfg
[PlexConnect]
enable_webserver_ssl = True
logpath = .
enable_dnsserver = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 192.168.0.10
certfile = c:\PlexConnect\assets\certificates railers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.0.10
enable_plexgdm = false
port_ssl = 443
You should not be altering settings.py at all.
Please provide the info requested in the “read before posting sticky”.
