Looking for help DOWNLOADING MOVIES and then transferring them to my desktop.
I signed up for Plex Pass, and can verify my movies has been downloaded, but cant figure out how to get it to my computet. I appreciate the help Thank you, Bobby Pero Naples, Florida
This button downloads into a strange location, mostly used for Plex itself, not for your own use. But if you WISH to find the files, you may find them somewhere in the following location: C:\Users\USERNAME\AppData\Local\Plex\Plex Media Server\Sync where USERNAME is your computer’s username. The media will be in one of the many numbered folders in this location, and there is no predicting which files will be where. Look in each folder, or use “Search” to look for *.* to find the files.
If you are the admin of your server, it’s much more recommended to use a web browser instead, click the triple dot ... menu for the movie/item, and click Save File instead. But then, if you are admin, you likely already have access to the movie files themselves, and this won’t help much.
