DSM disabled Plex after upgrading to DSM 7.2.2-72806
Anyone else have this problem?
If you were running DSM 7.0 → 7.2.1 before the upgrade,
This is normal.
Go to downloads.plex.tv
You’ll notice there is a DSM 7.2.2+ package choice in the dropdown.
Use this from now on.
(Synology changed the internal layout of packages for DSM 7.2.2. We had to adjust PMS as well)
To fix this:
dsm72 in the name.Thank you, I did DL the 7.2.2 for my machine. The step I was missing was uninstalling PMS.
Thanks again for the quick response… on a Sunday.
What if you did the install before you uninstalled pms?
disregard i fixed it
what did you do to fix it??
When you upgrade to DSM 7.2.2
Est-ce qu’avec cette procédure, on perds nos données dans Plex (association, catégories, collections) ??
No. If you select the KEEP option when uninstalling, the server data remains untouched.
Est-ce que je dois installer le DRM 7.2.2 avant de désinstaller Plex ? (je suis en 7.2.1 en ce moment )
J’ai pris une chance :
J’ai installé DSM 7.2.2
Désinstaller PMS
Réinstaller PMS avec package pour DSM 7.2.2+
Ca fonctionne nickel. Merci @tom80H
