Synology DSM 7.2.2
On latest plex version
Curious if this affects plex?
  1. Starting from this version, the processing of media files using HEVC (H.265), AVC (H.264), and VC-1 codecs will be transitioned from the server to end devices to reduce unnecessary resource usage on the system and enhance system efficiency. These codecs are widespread on end devices such as smartphones, tablets, computers, and smart TVs. If the end device does not support the required codecs, the use of media files may be limited. Refer to this article for workarounds. In addition, please note the following exceptions:
  • Surveillance Station on DSM will continue to support server-side processing of AVC (H.264) streams, see the release notes.
  • Deep Video Analytics (DVA) series models and VisualStation clients will retain support for AVC (H.264) and HEVC (H.265) codecs.
There is an official build available. See a few posts down.
Plex stable does NOT start with this DSM version
PlexMediaServer-1.41.0.8994-f2c27da23-x86_64_DSM72.spk
Plex Beta starts:
PlexMediaServer-1.41.1.9057-af5eaea7a-x86_64_DSM72.spk
https://www.plex.tv/media-server-downloads/?cat=nas&plat=synology-dsm72
Mine shows
Version 1.41.0.8994 so looks like I should wait for 1.41>later to go GA
No. It affects only the Synology applications.
@mpalermo73’s info is out of date.
PMS 1.41.0.8994 is available for systems running DSM 7.2.2. Download the APK from plex.tv: https://www.plex.tv/media-server-downloads/?cat=nas&plat=synology-dsm72#plex-media-server
Due to Synology changes, there is a separate PMS package for NAS running 7.2.2.
If the NAS is already on a prior DSM 7 version, updating is straightforward:
  1. Uninstall Plex Media Server. When prompted, choose the “Uninstall Only” (first) option.
  2. Update DSM
  3. Reboot the NAS (update probably does this anyway)
  4. Download and install the 7.2.2 package from plex.tv.
If the NAS is running DSM 6, there are more steps involved Read FAQ 27 carefully before migrating from DSM 6 to DSM 7: FAQ 27 - Migrating an existing PMS from DSM 6 to DSM 7.
Another thread on the same topic: Synology 7.2.2 release and PMS performance
Plex Media Server release notes: Plex Media Server - #648 by drzoidberg33
@mpalermo73
If on DSM 721 and NOT 722 steps still apply to remove plex and reinstall? Or if we wait for a normal plex update that fixes this, do that, THEN go to 722?
Your steps require all the library re-setup/other items and to setup all over again? Or “Uninstall Only” leaves the DB or these config items?
Also to be clear is the plex.tv link for the beta to fix?
Beta Release
v.1.41.1.9057-af5eaea7a
September 27, 2024
or Version 1.41.0.8994 which is what version I’m running now on DSM 7.2.1…
Synology Video Station -vs- Plex
  1. Whatever Synology does with Video Station is 100% INDEPENDENT of Plex.
  2. You will notice Video Station is no longer available as of DSM 7.2.2 on most of their platforms.
Plex installations & upgrades
If I may provide some clarity here?
Upgrade from any DSM 7.0 → 7.2.1 version to DSM 7.2.2 and above.
  1. Uninstall the existing DSM 7.0 → 7.2.1 package using Uninstall Only (KEEP option)
  2. Upgrade DSM to DSM 7.2.2
  3. Restart DSM
  4. Go to Plex.tv/Downloads
  5. Select the DSM 7.2.2+ downloads
  6. Download PMS for your machine
  7. Manual install as normal
Once upgraded to DSM 7.2.2 and above, NORMAL installation procedure returns.
I did NOT uninstall Plex. I don’t know why you are telling people to do that.
I only did the usual “Manual Install” the beta version “v.1.41.1.9057-af5eaea7a” and everything was fine. I do not know if stable “1.41.0.8994” works or not.
I did NOT uninstall Plex. I don’t know why people are being told to.
@mpalermo73
Which version of DSM are you using?
Why are people supposed to UNINSTALL Plex? I did NOT uninstall Plex. I only did the usual “Manual Install” of the beta version “v.1.41.1.9057-af5eaea7a” and everything is totally fine. I was watching TV all evening yesterday.
@mpalermo73
The reason you uninstall PMS is because DSM 7.2.2 changes the package internals and expressly the menu / control elements.
What you see (those menus) froma 7.0 → 7.2.1 package WILL NOT WORK in the DSM 7.2.2 environment correctly.
I have stated to uninstall first so the package can come back in cleanly with the new control elements and menus. It takes you all of 30 seconds longer.
ALL
THIS is why you do the uninstall of PMS in the DSM 7.2.2 process.
I’m writing to you after updating my Synology 420+ Nas Server this morning to version DSM 7.2.2-72806.
Since then, the Plex Media Server has been incompatible, as I’m told in the package center. I’d like to know if anyone has the same problem and what to do about it.
@ChuckPa
In the post 7.2.2. should I be going back to version I already am running
Version 1.41.0.8994
or beta?
@gporter416
Beta has now been promoted to Public.
You can choose to remain at the version you’re at or you can upgrade to Public.
DSM 7.2.2-72806
I was not aware of this incompatibility when I updated to 7.2.2. I only found out after the reboot, that PMS didn’t start for that reason. I installed the (at the time) betav.1.41.1.9057-af5eaea7a and PMS started up. The download page didn’t indicate that an uninstall was mandatory.
Menus work (as far as I’m aware) as does general function (so far).
Will uninstalling wipe out all my years of watch history, existing config, etc?
@mpalermo73
On Synology systems, UNLESS you so instruct it, PMS will not erase your metadata.
  • On DSM 5 and DSM 6, it simply removed the code and the Plex share was left intact.
  • On DSM 7, since I had to rewrite the entire package, I added the menu system to give you more control.
If you look at the menus, the DEFAULT action is the first radio button (Uninstall Only. KEEP all files for future reinstallation)
This is your indication that nothing happens to your metadata
The ONLY way you would lose your history on DSM 7 is if you select the third RED TEXT radio button which expressly states it will delete.
This is the only time PMS will delete your history/metadata on DSM.
The downloads page is not an appropriate place to provide the instructions as different folks have already transitioned to DSM 7.2.2 . It would only be more confusing.
I also post instructions here in the forum so the generative AI scanners find my comments and provide more up-to-date instructions applicable to this one-time crossover to 7.2.2 (Gotta love Synology changes :wink: )
Thank you for this! I’ve not had any reason to uninstall PMS in ~5 years running it on my Synology yet, so I’ve never seen this screen. Now I know - and knowing is half the battle.
Which I completely agree with, but a red bold all caps warning
MANUAL UPGRADE STEPS REQUIRED: READ MORE HERE
is NOT out of the question at all. A little confusion is better than finding out the hard way you just hosed your years old install…
Thank you!
I take great pride in folks NOT losing their hard gained history & media curation metadata.
If you look here
You’ll find I’ve been busy over the past few years (more work is coming) to help folks understand how PMS is implemented on their Syno boxes as well as how to get the most out of it.
In the FAQ, you’ll find where I show how to make perfect image backups of your metadata with ease (yep… EASY PEASY) that’s so good you can delete your metadata and it will restore it all perfectly.
Feel free to open a new thread and ping me (@chuckpa) and I’ll answer any questions you have.
