For some reason I can’t get DTS-HD to play, only DTS. I do see the option for 8 channel DTS-HD in the audio options but I can’t even tick the option. Was able to do it just fine in the old PHT.
To use DTS-HD decoding you have to disable passthrough completely or disable both DTS and DTS-HD passthrough.
You should use either the DTS-HD decoding or the DTS-HD passthrough option to play DTS-HD audio otherwise the DTS core will be used. With the DTS-HD decoding option enabled OpenPHT will decode DTS/-HD to PCM audio.
Thanks for the help again, I changed my audio settings to this and it works
http://i.imgur.com/I1mBCcK.jpg
