Duplicates without duplicate filename
Server Version#: 1.24.5.5173
Season 6 of American Dad is duplication with Season 5 without sharing filenames or directory paths.
Screenshot below
Capture|690x445
Try for a start and name the season directories as Season 05 instead of S05
ill give it a try =) thanks!
Nope, still the same
Capture
What Primary Agent is used for the library?
Have you checked, that it’s not an embedded Tag in the mkv file?
Also try and change Show directory from American Dad into American Dad! (2005) {tmdb-1433}
Looks OK to me
Capture
Once you have made the suggested changes to the files and folders I would do the Plex Dance. The Plex Dance in my experience tends to alleviate like 90% of errors like this.
Nope still f*cked Also did the Plex Dance after directory namechange
Did you check the embedded metadata for S05E01 as well?
And you forgot to tell us what Primary Agent you have selected for your Show Library!
Edit: And I myself generally avoid having any metadata embedded, and remove when I see them
I think I may have found an issue. The titles of the episodes that you have do not line up with the aired order of episodes. 100 A.D. was the first episode of Season 7 and In Country… Club was the first episode of Season 6. I would go through and make sure you have the right episodes matched up to the Aired or DVD order that is shown on TheTVDB.
Not according to IMDB
I went with the IMDB order for all the other seasons and everythings fine with those
By Primary Agent do you mean the “Movies” “TV Shows” “Music” etc?
IMDB doesn’t really matter as the agent doesn’t use it to match episodes. The episodes are matched from TheTVDB. As far as I know TheTVDB is the only source the Plex agent uses for episode matching.
I took the season 5 folder out of my Plex directory and did library update and cleaned out the trash, then Season 6 showed as it should. Put Season 5 folder back in, library update and now season 4 and 5 are duplicates…
Not so with the new agent :wink:
By default, the Plex TV Series agent uses the episode ordering based on TMDB. However, if you know that your files are named according TVDB, you can change the Episode Ordering preference (under Advanced) when creating or editing your TV library. Examples of the file naming/organization mentioned can be found at the end of the article.
Ref: https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
Edit Library, and select Advanced.
What’s shown under agent?
Edit: And you still haven’t answered what metadata for S05E01 looked like?
TV Shows ofc
Who would anyone select “Movies” when setting up their TV-show media library? o.O
Anything wrong here?
You didn’t look !
It’s either: TheTVDB or Plex TV Series
Under advanced it says: “Plex TV Series”
