Server Version#:1.43.0.10467-720010467
Player Version#:4.156.0
Seen similar problems in other posts, but it seems like every fix only corrects whatever show is being posted about.
Having a problem with Plex matching a show with the TVDB Aired order. The show is Henry Danger (TVDBid-284114). To get any potential questions out of the way, my naming conventions are correct, and the episodes are all numbered and named the same as what’s on the TVDB. I changed the episode ordering for the series to TheTVDB (Aired) after the default PLEX agent wasn’t matching correctly. I do have metadata in the files, but it all matches the episodes correctly and I don’t have Use Metadata turned on.
Having similar problems in every season, but I’ll just list the first issue as it’s indicative of what’s happening. In season 1, I have the following episodes:
Henry Danger - s01e01 - The Danger Begins (1).mkv
Henry Danger - s01e02 - The Danger Begins (2).mkv
Henry Danger - s01e08 - The Space Rock.mkv
Henry Danger - s01e09 - Birthday Girl Down.mkv
Henry Danger - s01e10 - Too Much Game.mkv
… (all 26 episodes as listed in the TVDB)
Everything is matched fine for the 1st 8 episodes, then episode 9 is matched as Too Much Game (which is episode 10). It still points to and plays episode 9, and every episode until the end of the season is matched that way (10 plays 10 but has the episode name and metadata for 11, etc.) Then episodes 25 and 26 are both named Jasper’s Real Girlfriend. Actually, looking now at the episode descriptions, they are different than TVDB as well, and 25 and 26 have the same name but different images and descriptions.
I’ve tried doing the PLEX dance and even tried naming them to match the PLEX agent series order and using that Agent. But nothing seems to fix the problem.
I know I could manually go in and edit every episode, but that seems like such a hassle when errors show up in every season.
Another example in Season 5, I have Henry Danger - s05e03-e04 - Thumb War.mkv which gets matched correctly on episode 3, but episode 4, which still points to the same file and says episode 4 has the name and data from episode 5.
Haven’t had this issue with any other series so far so not sure why it’s not matching correctly.
