DVBLogic TVButler DVB-C/T/T2 (100tc) Not finding any channels
Have tried on 3 different machnes 2 ubuntu and 1 fedora with latest plex, tested the usb stick with dvblogic’s own software works fine finding all channels, in the log when i do a whole uk freq scan i keep getting this 101 times
onetv_factory::DeviceGetListEx >>
Jun 03, 2017 18:11:45.045 [0x7fd623fff700] INFO - * onetv_factory::DeviceGetListEx. Found device 7449:256
Jun 03, 2017 18:11:45.045 [0x7fd623fff700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:32
Jun 03, 2017 18:11:45.045 [0x7fd623fff700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
Jun 03, 2017 18:11:45.145 [0x7fd61e7f4700] WARN - [E] onetv_factory::StartDevice. Device 2:4 not found
Jun 03, 2017 18:11:45.146 [0x7fd61e7f4700] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path 2:4, type 4, frontend 0
Jun 03, 2017 18:11:45.146 [0x7fd61eff5700] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Jun 03, 2017 18:11:45.146 [0x7fd61eff5700] WARN - [E] dvb_channel_scanner_t::do_scan. Tune failed for 578200,8,QAM16
Jun 03, 2017 18:11:45.146 [0x7fd61eff5700] INFO - * channel_scanner_t::scan_channels. Scanned 34 transponder out of 101. Channels found 0
Just Bought this as plex said it was supported so i hope they can find out why it does not work as thats £50 down the drain, was going to get a homerun but none around at the moment, starting to feel regretful.
There are a few other posts that deal with the described issue. You might want to keep an eye on https://forums.plex.tv/discussion/274039/dvblogic-tv-butler-no-channels-found
Can you post full Plex Tuner Service logs and Plex Media Server logs? We’ve worked with the DVB Logic guys, and they worked in our QA, not sure why folks are having issues with them but we’ll figure it out. They are definitely an officially supported tuner.
Have attached for viewing, wonder if its a driver issue needs v4l or permissions knowing ubuntu
Its not clear if i should of installed the dvblink server as maybe that is in control of the stick rather than plex, i could install mythbuntu as v4l drivers come pre installed kill the backend and then install plex
@keithah Thank you, I’m looking forward to use DVR & Live tv in Plex B)
Hmm i am sending this tvbutler back, you cannot even use it on another pc without having to pay for another license, i do not like microsoft style companies and rules, thats why i always used linux, it does not work with mythbuntu so usual i have bought the wrong type of stick knew i should have bought hauppuage dam!!!
Have now ordered a hd homerun i think this is the safest solution will now hae to wait 2 weeks for it to arrive cant wait
@djbridger12345 okay nice! where do you have buy the hd homerun?
@djbridger12345 if you would still like to get it working, here’s the steps to get the tv butler working:
