DVD Naming convention
I have a DVD set from HIllsdale College on Constitution 101. It is a 12 part series. Trying to determine if I should put this in the TV file or the movie file. My guess is the TV file but I do not think that it will pick up any of the metadata for it. Is that the best way to go or is there other suggestions?
Rip it to mp4 files.
Then embed the titles of the 12 “episodes” into their respective files.
Name and organize the files like for a regular tv show.
For this kind of content, I recommend you to create a separate library of the type ‘TV Shows’, but with the Agent set to ‘Personal Media Shows’.
You can add a poster for this show as a separate graphics file, right into the folder structure. https://support.plex.tv/articles/200220717-local-media-assets-tv-shows/
You’ll have to add the rest of the metadata manually.
Thank you. It worked and I did not have to covert my mkv file to mp4
