DVR Channel-EPG matching uncomplete UPC Cablecom Switzerland
Hi
There are some channels from which I can’t find the matching counterpart in the EPG list. It’s very strange, there are some gaps in the list. In the example below number 5, 7,10
Anyone with the same problem here?
A lot of european lineups are incomplete and have gaps.
Please report it at:
Reporting Gracenote EPG Data Issues
Dear developers, if the cable service provider is UPC (Cablecom) or does relay und that signal feed, then the problem is likely belonging a special signal behavior being used by UPC (Cablecom) Switzerland.
This because UPC (Cablecom) does have to serve three language areas within Switzerland and some TV channels are showing up on up to three locations within the channel setup.
I’ve got an explantion over at the SiliconDust forum here.
https://forum.silicondust.com/forum/viewtopic.php?f=127&t=67435&p=312711#p312626
As this list I made to explain the situation is quite long, I did place it here:
My question is now if there is a way to “over write” this “faulty placed” channels with direct accessing the proper TV channel and frequency through Plex Live DVR&TV by using an xmltv file or so?
