I just got myself an HDHomeRun Can watch TV fine in through Plex. But for the records is there a way you can set the default folder for recordings? He is defaulting to TV Shows I want it to go a folder called DVR so I can do the clean up of the commericals etc.
Got it sorted after the first recording had finished when I set to record another item that was set to the same folder.
