Hi
I have a synology nas ds416j that I am currently hosting my plex service from, The tuner dongle I have just purchased is not recognised. It seems to be a bit Russian roulette with these things despite researching before the purchase.
Is it possible to run the dongle from a pc that I have running on my lan and connect it to the plex service on the Linux nas?
Or shall I run the plex server from the pc and use the nas only as storage?
Thanks in advance
Server Version#:
Tuner Make/Model: Hauppauge
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
You could set up a second plex server instance on the PC which only does live TV and DVR.
Or you avoid all of these driver issues by getting a Silicon Dust HDHomeRun device. It is connected to the network directly.
Awesome thanks for the reply, much appreciated
if the PC is switrched ON all the time, you might as well move your plex server fully there. It may be able to transcode video much faster than your NAS.
That’s on the cards as some of my media files struggle at the moment, thanks for your help
I’m in the process of moving the plex server, I deleted the instance of the nas server on the web gui. Despite doing this when I log on again on the pc with server installed it can’t find the new server and requires me to download. / restart etc etc. What am I doing wrong here?
Which OS on the server?
Any containerization or virtualization used?
its windows 10, basic install home pc
the server install is the same machine im lauching the web gui from
Initial setup must be done with a web browser from the same machine (or at least the same local network), using the “local” web app. ( http://127.0.0.1:32400/web )
Browser should be in ‘incognito’/‘privacy’ mode.
Disable all browser add-ins.
Additional hints here: Cant find library options so i can add my movie libary
Boom! the registary sorted it, must have had some mess in there from old old install. thank you so much!
According to our supported tuner article, https://support.plex.tv/articles/225877427-supported-dvr-tuners-and-antennas/, Hauppauge tuners are not supported on NAS devices.
I based my decision from the info on the synology site, the model I have didn’t support that model
Starting from DSM 6.2, the USB device drivers, including printers, cloud printers, DAC/speakers, Wi-Fi dongles, DTV dongles, 3G/4G/LTE dongles, and Bluetooth dongles will no longer be updated.
So that’s apparently a dead end anyway.
That is info on compatibility with their DiskStation software. That would not apply to other programs like Plex.
