I’m really frustrated,
I moved and so I was really happy that I now can use the Plex DVR because there is now DVB-C availible.
I bought a WinTV-dualHD wich has two tuners, but there was no chance that the card will find a channel, so I read in the board,
that I have to install another firmeware, what I did.
The card is now able to find all my channels, but in Plex only 1 Tuner is showing up.
In the first step this is okay for me, so I started the channel searching.
Next Problem:
All my Channels are here but all the availible EPG are not matching:
I have one of the biggest Cable-Providers in Germany (Unitymedia BW) - not a SINGLE Channel was fitting,
so I took the EPG from Unitymedia BW wich has all Channels but a complet wrong order and matched them manual.
I matched arround 200 Channels manual-> really frustrating.
BUT:
Now there is another big Problem, when the EPG Data were initalizing, it says** EPG is empty, please check your CFG**
I read in the board to uncheck all the radiostations and not needed Channels, now I have around 36 active channels, but still no
EPG-Data.
I hope someone can help me, I’m a Plex User for many years, but I nerver were that frustrated.
Thanks inbefore!!
