DVR Guide not accepting postal code
Hello, since Plex media server update today to latest on RPI the DVR will not load the TV guide anymore. I have deleted and setup the HD HomeRun DVR again but Plex does not accept the post code and is asking for an xml file. Is this a known bug?
Not that I am aware of. Can you provide your server logs after trying to add it. Does it work if you add a nearby postal code?
Hi, I just set up a DVR and noticed it only wanted the first two digits of the post code, anything else didn’t work - might be worth a try…
Yes for the UK it is only the first part of the Post Code as in the example that shows up in the post code field
Would need debug server logs during setup if issue persists even when entering post code in the right syntax
