DVR in 1.16.1 and .2 totally broken
I tried deleting the DVR and the EPG/Guide is not deleted.
I tried reverting to 16.1 images after June 21st and the same behavior.
After deleting a DVR the screen for DVR management fails to load many times and when allows adding one the process fails at the end.
I managed to resolve by following a suggestion on the forum:
  1. Downgraded to 1.16.0
  2. Removed the old DVR, this type the EPG was removed too
  3. Upgrade back to 1.16.2
  4. Recreated the DVR with the new EPG source. This time the creation completed the Guide Refresh started
Quite a complex process and it seems the Guide Data is worse now than was before, many times no poster added to the program.
I could not find the 1.16.0 package on the Plex site, so I googled for it, and finally for my Synology DSM 6.0 case, I found it here: https://luenepiet.de/public/Synology/Plex%20(Server)/Intel%20-%2064-bit/
Hope this helps.
Sadly, much worse. Plex are on it and you should report your problems here.
Plex are not very good at communicating the status, so you cannot assume your issues have been reported.
I finally decided to stop the Plex Live TV and DVR. In my space/context, https://zattoo.com/ comes with better digital experience across fixed and mobile device access with almost no cost.
looks good - good luck!
I have been having trouble with the guide for several weeks. I have tried several solutions listed in different locations in the forums. Today I found a solution that worked for me. You may want to give it a try.
The solution was provided by Howard Gilbert: https://forums.plex.tv/u/howardgilbert
