DVR not recording past 1 hour
Server Version#: 1.24.0.4930
Tuner Make/Model: HD 4K Scribe
Guide/Lineup name: Any channel (only one hour)
Using XMLTV?:
Channel number/Name:
I’m only getting one hour of recording on movies and sometimes TV shows if they run longer than 60 mins. Not sure what’s going on, I have extended the time frame for the recording window.
Search the Plex Media Server.log for failed and space.
Recordings use about 6GB per hour of your tmp space, so if you are using a Ramdrive or Nvidia Shield make sure there is enough space.
