Server Version#: 1.23.6.4810
Player Version#: Web
Tuner Make/Model: HDHomeRun EXTEND
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: All
Short version, Plex starts recording, records for about 46 seconds, and that’s all it records. So far:
- Verfied permissions on storage.
- Set custom Transcorder temp directory and verified permissions.
- Removed tuner and readded.
- Tried different settings on the tuner’s built-in transcoder.
- Disabled commercial detection.
So far no luck, just the same results where the DVR records for less than a minute then stops and that’s what’s added to the Plex library.
For a sanity check, I have the HDHomeRun application on my Windows laptop, tuned into NBC and everything coming from the tuner is looking great. No video drops. Looking at the HDHomeRun:
| Modulation Lock | 8vsb |
| Signal Strength | 97% |
| Signal Quality | 90% |
| Symbol Quality | 100% |
So good signal strength and quality. No dropouts while watching live not via Plex.
Plex Media Server Logs_2021-07-23_13-54-14.zip (2.2 MB)
ng
