DVR schedule shows "No upcoming airings" yet episodes appear in guide
This specific bug has just been fixed in Plex Media Server beta 1.20.1.3213 released today
See Release Note: Plex Media Server - #360 by StSimm1
  • (DVR) Server would display incorrect times under “Limit Airing Times To” advance recording option (#11362)
N.B. Downgrading from this release may result in DVR recordings with an airing time restriction failing.
So if ever downgrading from this beta release, any DVR schedules created with “Limit to Airing Time” would need to be deleted and recreated.
(Note: there is still a Plex Web display bug relating to use of “Limit of Airing Time” where there may be occasions when the “DVR Schedule” and “Recording Priority” show the wrong times - this does not affect the actual scheduling that Plex Media Server is using and is just a Plex Web display bug that will get fixed)
I have been running using version 1.20.1.3252 for some time now and everything is looking good so far. No missed recordings and all recording times are accurate (the 1 hour offset problem is fixed). Thank you for your support!
The Plex Web issue i mentioned earlier is now also fixed - the version of the Plex Web app that has the fix is 4.42.1
  • Fixed an issue that could lead to the wrong DVR recording info being shown in the calendar view
I am on 1.20.1.3252 and whenever I choose to record all episodes, it shows no upcoming shows, but if I choose just this episode, it works.
I have left the adv. settings as default and “HD Only” is not selected.
Best regards
Martin
The Plex Web fix I mentioned earlier here is only currently available in the hosted Plex Web app through https://app.plex.tv/desktop - the fixes are not in the current Plex Media Server versions (1.20.1.x 1.20.2.x 1.20.3.x) bundled Plex web app.
