Dvr stopped working
Since a few months Live TV is no longer working for me. When clicking on any channel from the guide, I get a spinner then an error message telling me the session ended.
I’m running PMS in docker on Ubuntu. Current version is Version 1.18.2.2029. The server is connected to a WinTV-dualHD which I picked because it was officially supported. It is detected and shows up OK and if I remove it from the settings, add it again and do a rescan everything seems to work, channels are found etc.
PMS logs show that the transcoder isn’t getting anything to transcode apparently:
Nov 20, 2019 11:38:47.610 [0x7f6dacff9700] ERROR - [Transcoder] [h264 @ 0xf84ec0] non-existing PPS 0 referenced
Nov 20, 2019 11:38:47.612 [0x7f6dda9b2700] ERROR - [Transcoder] [h264 @ 0xf84ec0] decode_slice_header error
Nov 20, 2019 11:38:47.614 [0x7f6dacff9700] ERROR - [Transcoder] [h264 @ 0xf84ec0] no frame!
Nov 20, 2019 11:38:47.701 [0x7f6dda9b2700] ERROR - [Transcoder] [h264 @ 0xf84ec0] mmco: unref short failure
Nov 20, 2019 11:38:56.839 [0x7f6dda9b2700] ERROR - [Transcoder] [h264 @ 0x1c8df00] mmco: unref short failure
Nov 20, 2019 11:38:57.880 [0x7f6db8ff9700] ERROR - [Transcoder] [h264 @ 0x1c8df00] mmco: unref short failure
Nov 20, 2019 11:39:00.734 [0x7f6dcbfff700] ERROR - [Transcoder] [eac3_eae @ 0x20c0d80] Sample rate 0 invalid
Nov 20, 2019 11:39:00.735 [0x7f6dda9b2700] ERROR - [Transcoder] Error while processing the decoded data for stream #0:1
The only hints that I found on this forum are from users who basically wiped out their PMS install and did a fresh new install and somehow it worked again. I’d really rather not have to do that. Any other advice would be greatly appreciated :slight_smile:
I bought a licenced Plex USB tuner and a Plex pass and I get zero support? I’m rather disappointed, Plex is an awesome service but it’s the first time I’m having trouble with it and I feel rather lonely.
Up?
:disappointed:
