Live TV stops tuning to any channel
Server Version#: 1.23.6.4881
Player Version#: N/A
Running my PMS on CentOS Linux release 7.9.2009 (Core) x64 with SELinux set to Permissive. I use a combination of a HDHomeRun tuner and xteve (EPG) sources for my local USA channels and some channels in France.
This started happening recently, where LiveTV stops working, regardless of player and I have to restart plexmediaserver to fix it. If I check the status before I restart, it’s still running and the server page loads no problem.
Could someone take a look at the logs and let me know what’s up? I tried looking myself but I can’t tell what’s going on.
Thanks so much!
Plex Media Server Logs_2021-08-07_15-28-31.zip (2.8 MB)
Anybody out there that can help?
And it happened again. This is getting annoying. Plex Media Server Logs_2021-08-11_17-05-25.zip (2.1 MB)
I dug into the logs more and found these in the Plex Media Server 1.log:
Aug 11, 2021 16:45:11.867 [0x7f0d77e46b38] ERROR - [Transcoder] [NULL @ 0x7fa22fb125c0] SPS unavailable in decode_picture_timing
Aug 11, 2021 16:45:11.867 [0x7f0d77c4fb38] ERROR - [Transcoder] [NULL @ 0x7fa22fb125c0] non-existing PPS 0 referenced
Aug 11, 2021 16:45:11.867 [0x7f0d77e46b38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] SPS unavailable in decode_picture_timing
Aug 11, 2021 16:45:11.867 [0x7f0d77c4fb38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] non-existing PPS 0 referenced
Aug 11, 2021 16:45:11.868 [0x7f0d77e46b38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] decode_slice_header error
Aug 11, 2021 16:45:11.868 [0x7f0d77c4fb38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] no frame!
Aug 11, 2021 16:45:11.868 [0x7f0d77e46b38] ERROR - [Transcoder] [NULL @ 0x7fa22fb125c0] SPS unavailable in decode_picture_timing
Aug 11, 2021 16:45:11.868 [0x7f0d77c4fb38] ERROR - [Transcoder] [NULL @ 0x7fa22fb125c0] non-existing PPS 0 referenced
Aug 11, 2021 16:45:11.869 [0x7f0d77e46b38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] SPS unavailable in decode_picture_timing
Aug 11, 2021 16:45:11.869 [0x7f0d77c4fb38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] non-existing PPS 0 referenced
Aug 11, 2021 16:45:11.869 [0x7f0d77e46b38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] decode_slice_header error
Aug 11, 2021 16:45:11.869 [0x7f0d77c4fb38] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] no frame!
Aug 11, 2021 16:45:11.869 [0x7f0d77e46b38] ERROR - [Transcoder] [NULL @ 0x7fa22fb125c0] SPS unavailable in decode_picture_timing
Aug 11, 2021 16:45:11.870 [0x7f0d77c4fb38] ERROR - [Transcoder] [NULL @ 0x7fa22fb125c0] non-existing PPS 0 referenced
client_loop: send disconnect: Broken pipe] ERROR - [Transcoder] [h264 @ 0x7fa22fb10b00] SPS unavailable in decode_picture_timing
Which is strange because I’ve had transcoding turned off on my server for a few weeks now.
I also saw these but unsure if they could be causing my problem:
Aug 11, 2021 16:49:15.435 [0x7f0d7736ab38] ERROR - downloadContainer: expected MediaContainer element, found html
Aug 11, 2021 16:49:15.435 [0x7f0d7736ab38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:21/metadata/plex%3A%2F%2Fshow%2F602a651da5d49e002cd18ea7
Aug 11, 2021 16:49:15.449 [0x7f0d77347b38] ERROR - downloadContainer: expected MediaContainer element, found html
Aug 11, 2021 16:49:15.449 [0x7f0d77347b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:21/metadata/plex%3A%2F%2Fshow%2F5fc6acac75bdc2002e9e54c0
Aug 11, 2021 16:49:15.958 [0x7f0d7738db38] ERROR - downloadContainer: expected MediaContainer element, found html
Aug 11, 2021 16:49:15.958 [0x7f0d7738db38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:21/metadata/plex%3A%2F%2Fshow%2F602a651da5d49e002cd18ea7
Aug 11, 2021 16:49:15.964 [0x7f0d77324b38] ERROR - downloadContainer: expected MediaContainer element, found html
Aug 11, 2021 16:49:15.964 [0x7f0d77324b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:21/metadata/plex%3A%2F%2Fshow%2F5fc6acac75bdc2002e9e54c0
Aug 11, 2021 16:49:16.438 [0x7f0d77324b38] ERROR - downloadContainer: expected MediaContainer element, found html
Aug 11, 2021 16:49:16.438 [0x7f0d77324b38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:21/metadata/plex%3A%2F%2Fshow%2F602a651da5d49e002cd18ea7
Aug 11, 2021 16:49:16.441 [0x7f0d7736ab38] ERROR - downloadContainer: expected MediaContainer element, found html
Aug 11, 2021 16:49:16.441 [0x7f0d7736ab38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:21/metadata/plex%3A%2F%2Fshow%2F5fc6acac75bdc2002e9e54c0
Anybody have any suggestions?
Man this happens to me all the time.
What model HDHomeRun are you using? I’ve got a HDHR3-US running PMS on Ubuntu.
I’m rocking the new HDHR5-4K. Wasn’t having any issues with it though, this just started happening like a week or so ago.
Is there still no one that can help shed some light on this issue?
So it has now been a week since the last crash and I believe that is because we aren’t watching much Live TV. I’m wondering if some connections are getting stuck and not closing.
This problem has cropped back up again and I’m running the latest version of PMS. Anyone available to help?
