since I find LyricsFind quite unreliable, I decided to put txt lyrics files on my server. Now the problem is that, even if I refresh artist/album, the lyrics panel is empty despite the fact that the txt file correctly contains the lyrics.
Are you using Linux (or a derivated OS) on your server?
If so, have you checked file access permissions?
user plex needs to have at least ‘read’ permissions.
Do also check the text encoding. UTF-8 is recommended.
